I need this hose - Mustang Evolution
Old 05-28-2008, 12:03 PM   #1
I need this hose
it connects to a plastic hose that comes from the throttle body and then it connects to the right side valve cover
family ford ordered 2 hoses for me that looked nothing like this and then i checked at a salvage yard and no luck there either.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 05-28-2008, 12:20 PM   #2
Re: I need this hose
use a piece of pcv hose from a local parts store, that piece collapses anyway from oil getting in it.
SimplyOrange is offline   Reply With Quote
Old 05-28-2008, 12:38 PM   #3
Hey man, register on TorqueAddicts.net, someone on there should have one local. I don't have any laying around...well I say I don't, I'll look around tonight, I have an extra throttle body, plenum, and a few other GT parts laying in the closet.
Old 05-28-2008, 12:46 PM   #4
Yeah, just get some hose from autozone or something and run that. I have that hose at home, but I cut one end off it so it won't help you at all. I picked up a 2' piece of hose from o'reilly's and cut to size for my application...do the same. It will only be a couple bucks.
Old 05-28-2008, 12:48 PM   #5
that hose has a bad habit of collapsing when it gets oil in it because it doesent have nylon reinforcement.its actually better to get regular pcv hose from a parts store.
Old 05-28-2008, 01:27 PM   #6
well the car has a hose on it from the parts store right now. the car doesn't seem to idle right with that hose on there. i did see one engine at a scrap yard here and it had an all plastic hose for the one i needed. i guess ford changed the design on it.
Old 05-28-2008, 01:28 PM   #7
It may not be the hose....or it may be there is a leak in the hose connections. A hose is a hose is a hose...it shouldn't cause/prevent any idle issues unless there is a leak somewhere in a connection.
Old 05-28-2008, 01:35 PM   #8
this is true
Old 05-28-2008, 01:38 PM   #9
it's a strange deal. i never noticed the crack in that hose until i was changing the plugs a few weeks ago. we heard a small hissing sound and saw the crack in the hose. the car ran fine though and it didn't idle funny until i put the other hose on. we even tried to use hose clamps but that really made it run like ****. now it seems to be doing ok for now except for the funny idle. i keep an eye on it every now and then. once you start the car the rpms go up and down a little bit but then it will stay at around 800 for a while.
Old 05-28-2008, 01:46 PM   #10
ur having vacume problems, use the hose clamps again and take a can of carb cleaner with a straw and spray in different areas, if it idles up, check that area for a vaccume leak.
Upper radiator hose OIF2007Mustang General Mustang Discussion 0 03-30-2010 03:48 PM
busted hose Senorjizzy Pre-2005 V6 Mustang 10 08-09-2009 10:59 PM
Air hose upton7 1996-2004 Mustang GT 5 06-02-2009 09:31 PM
what coolant hose is this? jimmy_beaner 1996-2004 Mustang GT 53 02-14-2009 10:13 PM
Name that vacuum hose... A5295 1979-1995 Mustang GT 3 11-27-2007 06:17 PM
07:44 PM
