Evap leak Small - Mustang Evolution
Old 06-05-2008, 05:54 PM   #1
Evap leak Small
My Question is when my engine light came on, the car started running very poor, loss of power, the idle is rough jumps up then back down. I can also now notice a slight miss. I had the code read at advance auto it came back Evap leak small. I really dont feel the evap leak is the source of the all the symtoms. Please help.
jmarcinko00gt is offline   Reply With Quote
Old 08-13-2008, 12:26 AM   #2
Re: Evap leak Small
Code on my 2001 mustang gt said I had a Evap small leak. Where would this be located at .Thanks!
shawn1982ncnb is offline   Reply With Quote
Old 08-13-2008, 06:26 AM   #3
Herbstang's Avatar
Re: Evap leak Small
OBD-II Trouble Code: P0442 Evaporative Emission Control System Leak Detected (small leak)
Old 08-13-2008, 06:38 AM   #4
Re: Evap leak Small
i would agree it is probably the gas cap, i had that code 2 years ago and a new cap fixed it.
SimplyOrange is offline   Reply With Quote
Old 08-13-2008, 06:52 AM   #5
Herbstang's Avatar
Re: Evap leak Small
Had the same issue with mine !! I tighten the cap disconnected the battery to clear the code If that doesn't work Time for a test to find the leak
The EVAP small leak test applies vacuum to the evaporative emission (EVAP) system and monitors vacuum decay. The powertrain control module (PCM) monitors the fuel tank pressure (FTP) sensor signal to determine the vacuum decay rate. At an appropriate time, the PCM turns the EVAP canister purge valve ON (open) and the EVAP vent valve ON (closed). This allows the engine to draw a vacuum on the EVAP system. At a calibrated time, or vacuum level, the PCM turns the purge valve OFF (closed), sealing the system, and monitors the FTP sensor input in order to determine EVAP system vacuum decay. If the system detects a leak larger than a calibrated amount DTC P0442 will set.
The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
inspect for leaks in the following locations:
The EVAP system purge pipe.
The EVAP vapor pipe.
The EVAP vent hose/pipe.
The fuel fill pipe/hose and fuel fill cap.
The EVAP canister.
The EVAP canister vent valve.
The EVAP canister purge valve.
The fuel sender assembly and/or seal.
The FTP sensor seal.
The fill limiter vent valve, pressure relief valve, rollover valves, and fuel tank.
Old 09-03-2008, 09:59 AM   #6
Re: Evap leak Small
has the problem been fixed, my 01 is doing the same thing, running hard, and loss of power not to mention its using a crap load of gas. I dont see any gas leaks, but i dont think that would cause the car to run like crap.
drums4life0922 is offline   Reply With Quote
Old 09-03-2008, 10:26 AM   #7
Herbstang's Avatar
Re: Evap leak Small
PM sent my issue was the gas cap. sounds like your's is a purge valve stuck or a large vac leak
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 08:32 PM
2004 GT EVAP Questions SSgt Dan 1996-2004 Mustang GT 16 09-25-2009 01:20 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Small Rant... MidnightSpeed The Bar 23 11-14-2006 01:51 PM
small photoshoot Dark02Pony Pictures and Videos 3 10-16-2005 12:30 AM
04:50 AM
