Is my transmission slipping? - Mustang Evolution
Old 03-13-2010, 03:30 PM   #1
My car will be going smoothly and then all of a sudden jump up in rpms. But its not consistant, I can drive my car one day and it will be perfectly normal but then again i can drive it another day and it will do it a lot. Also when im going down a fill and coasting sometimes it will feel like its not coasting right and sometimes ill actually lose a little speed instead of gaining it. My car is an Automatic 1994 Ford Mustang. Is my transmission slipping? Does my Transmission fluid need changed? I dont know what the problem is, do you?
Dinari is offline   Reply With Quote
Old 03-13-2010, 04:16 PM   #2
when's the last time you changed the A/T fluid? if the RPM is increasing w/o vehicle speed change then bumping into a gear that would mean that the trans is slipping. my car does it once in a while, but it doesn't mean that my trans is slipping.
if you went over 35K miles w/o changing the A/T fluid my guess is don't bother changing it. you're going to have to run that transmission till its dead. i know, expensive to pay for but just buy a new mustang for same price as the repair order.
imported_dallas is offline   Reply With Quote
Old 03-13-2010, 04:30 PM   #3
I would start by having the tranny pan dropped and putting in a new filter and replacing the lost fluid and see what happens.
comhghan is offline   Reply With Quote
Old 03-13-2010, 04:49 PM   #4
Check your transmission fluid to make sure its not low, or if you have the cash take it in for a transmission flush.
christophe is offline   Reply With Quote
12:27 AM
