Why does my 1999 Ford Mustang GT skip? - Mustang Evolution
Old 03-13-2010, 07:00 PM   #1
What would cause the check engine light to come on while skipping? Is there an easier way to find out what the cause is rather than taking it to a dealership?
abiram is offline   Reply With Quote
Old 03-13-2010, 07:21 PM   #2
first i need to know wat u mean by skip like does it skip gear or does the tires over rotate or what
derrold is offline   Reply With Quote
Old 03-13-2010, 07:50 PM   #3
The best way and cheapest would be to stop
by autozone and they will plug in a scanner
to see what code is in your computer.
If you get a code P0301 to P0308 (8 cylinder)
that will lead you to a skipping for
that cylinder.
Example=P0301 would be cylinder #1
P0302 would be cylinder #2,ect...
Those car are famous for burning out the coil,boot or
ignition wire depending what your vehicle has.
If it is another code it will be something else.
You will also get other codes when your vehicle
skip because you would have a cylinder not
burning the fuel in that cylinder.
hulbard is offline   Reply With Quote
Old 03-13-2010, 08:07 PM   #4
pull the bulb out , easy fix
beagan is offline   Reply With Quote
10:15 AM
