No power below 3k - Mustang Evolution
Old 06-08-2008, 09:08 PM   #1
No power below 3k
So I just bought my wife a 97 GT last week, the first Ford in our family. It runs a little rough. When idling it seems to (best way to describe it) spit. It doesn't go dead. I had to fix the tube going from the intake manifold to the left hand valve cover as it was kinked, this did not fix the issues. The car doesn't have any power below 3K. it's an auto, when cruising it sputters a little, this seems to go away with a higher RPM, when you put your foot down, the car will down shift but doesn't put you in the seat like it should, but when it gets above 3K you can feel the power turn on, almost like it has a turbo on it, the power is minimal and the engine output still seems a little weak. I’ve read the threads on the IAC and have tried that, it does run a little better but now you can hear the valve sticking a little as now the IAC whistles, it sounds cool with the hood closed like it’s supercharged, but still running rough. Is there anything else that could cause this as I am in Japan and will be making a trip to the US soon to collect parts?
Thanks for the help
JP
WHAT'S IN MY GARAGE;97 Red Mustand GT 4.6L (the wife wanted a toy, the wife got what she wanted, and she looks sexy in it:love:)03 Red BMW 330XI (the wifes first baby, put in storage April 2007:cry:, will come out in May 2011 and have less than 20K on the clock)96 White R33 GTR (it's slow, really slow for a car with four wheels and a small rocket under the hood, but faster than the Mustang:eek:)
jjpea is offline   Reply With Quote
Old 06-10-2008, 06:52 PM   #2
99MustangGTman's Avatar
Send a message via AIM to 99MustangGTman
Re: No power below 3k
check the spark plugs, COPs, change the fuel filter and check the fuel injectors.
99MustangGTman is offline   Reply With Quote
Old 06-11-2008, 09:23 AM   #3
what are the COPS?
thanks,
JP
Old 06-11-2008, 09:28 AM   #4
Originally Posted by jjpea View Post
what are the COPS?
thanks,
JP
The COPS are the Coil On PlugS. Basically, they replaced the distributor.
They will be the parts attached to your spark plugs. Here's a question tho, did the 97's have COPS? Or did those first show up in 99? My brain is taking a break and I can't remember right now.
Old 06-11-2008, 09:50 AM   #5
97 had 2 coils with 4 plugs on each one
SimplyOrange is offline   Reply With Quote
Old 06-11-2008, 09:51 AM   #6
I thought that was how gabe's 96 was as well...so, no COPS then?
Old 06-11-2008, 09:57 AM   #7
no, i would check the fire on both sides but its probably not a coil pack since the power comes back on after 3K check the air intake temp sensor and the mass air, they both have been known to cause a problem like that.
Old 06-11-2008, 10:21 AM   #8
Wow my mistake a totally forgot 97s had 2 seperate coil packs, well in that case check the plug wires
More Power V6NOS01 Pre-2005 V6 Mustang 15 03-19-2008 01:50 PM
no power!! sledgehammer 1979-1995 Mustang GT 2 03-16-2008 09:56 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
Power or Looks Black95GT The Bar 17 08-18-2003 12:10 PM
09:52 AM
