Im changing the Air Intake Manifold on my 1996 4.6 Mustang? - Mustang Evolution
Old 03-26-2010, 06:15 PM   #1
What else should I replace while I have everything taken apart? The car's mileage is at 150,000. I definitely need a tune up, I need a new alternator. Any other thoughts?
woolcott is offline   Reply With Quote
Old 03-26-2010, 06:46 PM   #2
The 4.6 does not have cap and wires like a push rod v8. It is a coil on plug design. I had to change mine at 58,000 because in '99 it was a poor design by Ford and the thermostat housing was plastic along with th rest of the manifold. It crack and i lost a lot of coolant. If that what you have, upgrade to the 2002-2004 manifold. Ford fixed the issue by making the thermostat housing metal.
Anyway, while you have it it apart, its good to go ahead and change your plugs. Check all you fuel lines and rails to make sure they are in good working order. When i changed mine, i did a complete upgrade to all the induction system. I put on larger throttle body, ported plenum, larger mas air sensor and cold air intake. it wold really help your car breathe for being an high mileage motor.
sein is offline   Reply With Quote
Old 03-26-2010, 07:29 PM   #3
I would check the plugs and probably change the wires and distributor cap. Also, at 150, 000 I would check the oil if it hasn't been done in a while. If it a fuel injected motor, I woulld also check the injectors and probably clean them.
Nevada is offline   Reply With Quote
09:53 PM
