1996 ford mustang gt engine swap? - Mustang Evolution
Old 03-26-2010, 08:15 PM   #1
i am going to put a new motor in my 96 gt and want to go with one of the new 3 valves but dont know if i can any help please?
derwynn67 is offline   Reply With Quote
Old 03-26-2010, 09:04 PM   #2
I haven't heard of anybody swapping in the 3 valve 4.6L into a 96-04 Mustang. But plenty of people swap in the 4 valve 4.6L, in fact it's so common that there are companies that make kits with the necessary parts for the install. I would go with the 4 valve if I were you. You can even use your stock ECU with a 4 valve swap, you just need a custom tune for it.
drogo is offline   Reply With Quote
Old 03-26-2010, 09:12 PM   #3
I don't see why not. It should bolt in pretty easily. You will need the engine computer and possibly a few other items from the 3V engine and you should know that your transmission is probably a good bit weaker than the one in the 3V engine cars.
meinyard is offline   Reply With Quote
Old 03-26-2010, 09:26 PM   #4
if both are the 4.6 you should only need the computer for that motor. the fuel pump may need changed as well
cleavon is offline   Reply With Quote
09:43 AM
