How do the headlights work on the 1997 Ford Mustang? - Mustang Evolution
Old 04-01-2010, 02:45 AM   #1
For some reason my lowbeams work, but as soon as I turn the high beams, my lights go out. I think the actual switch is fine since the light comes on in the dash. How can I diagnose the problem?
gabrio is offline   Reply With Quote
Old 04-01-2010, 03:22 AM   #2
just get a wiring diagram and start narrowing things down with a volt meter or test light. sounds like you have a ground somewhere that could be bad either that or somehow both bulbs burned out. because when you switch to high beams both low and high beams are not on, just highs
broughton is offline   Reply With Quote
Old 04-01-2010, 03:55 AM   #3
Because the headlights draw higher amps, there's usually a relay just for them. If neither bulb works, start looking for a high beam relay. It'll be in the relay main power distribution box, usually on a wheel well liner. Fords seem to like the driver's side.
felan is offline   Reply With Quote
04:03 PM
