How do i get my 2002 ford mustang out of park? - Mustang Evolution
Old 04-03-2010, 08:15 AM   #1
i tryed everything to think of im just wondering where the override was for it and there is a black wire just hangging there by the brake pedal
riki is offline   Reply With Quote
Old 04-03-2010, 08:28 AM   #2
That wire might have come unhooked from the switch that only lets you shift out of park when the break is applied.
taurino is offline   Reply With Quote
Old 04-03-2010, 09:07 AM   #3
Take the cover off the console where the shift lever comes out. On the right front you will see a white plastic lever with a small wire cable attached. Disconnect that cable. You won't have to put your foot on the brake to take it out of park.
raedford is offline   Reply With Quote
Old 04-03-2010, 09:22 AM   #4
There is no override you can always unhook the cable and shift it manually just be sure to have the park brake on
gaven60 is offline   Reply With Quote
Old 04-03-2010, 09:58 AM   #5
Is there a key slot next to the shifter? If there is stick your car key in it.
imported_driscoll is offline   Reply With Quote
05:31 PM
