Where are the spark plugs located on a 2001 ford mustang gt? - Mustang Evolution
Old 04-12-2010, 05:00 AM   #1
what would be the best way of changing them also???
rosswald is offline   Reply With Quote
Old 04-12-2010, 05:45 AM   #2
Some of these answers come from left field. The 99-up GTs have coil on plug setups and the plugs are in the head almost vertical under each coil. Should take 20-30 minutes taking your time. No need to lift the fuel rail. I believe it is a 7 or 8mm socket used on each bolt to remove the coil, but don't quote me because it has been a while.
Derby is offline   Reply With Quote
Old 04-12-2010, 05:57 AM   #3
on the sides of the block, near the bottom
some you can get from the top, and some you can get from underneath.
dubh is offline   Reply With Quote
» Members Mustangs
Pwny
BaSohol
Squat
5Point
Add your Mustang
05:08 AM
