Oil in the Radiator/Reservoir Box? - Mustang Evolution
Old 12-11-2011, 11:00 PM   #1
I have a 2001 Mustang Roush Edition and noticed that it uses oil a little more than it should and seeing that it is in the Radiator along with the water or in the Reservoir box... What could be the problem and what to fix it?
gabrio is offline   Reply With Quote
Old 12-11-2011, 11:13 PM   #2
Blown cylinder head gasket. The cure = Fit new tiers.
mmalky: 50 years diagnosing and repair small and large engines.
izaac is offline   Reply With Quote
Old 12-11-2011, 11:58 PM   #3
You have a cracked block, the easiest repair attempt you can make is to go to your local auto parts store and purchase an additive that you can add to your radiator to fix the crack. Liquid glass or also called water glass is a good one for this.
Shilo is offline   Reply With Quote
Old 12-11-2011, 11:59 PM   #4
It usually means you have a cracked block.
stanhop is offline   Reply With Quote
Old 12-12-2011, 12:29 AM   #5
http://www.ricksfreeautorepairadvice...ad-gasket-leak
Felten is offline   Reply With Quote
Old 12-12-2011, 12:58 AM   #6
mostly likely its a blown headgasket
Fahroni is offline   Reply With Quote
Old 12-12-2011, 01:06 AM   #7
next time buy a chevy ford makes a terrible product
hulbard is offline   Reply With Quote
04:48 AM
