Clutch pedal vibrates and makes a vibrating noise at the low 1000 - 2000 rpms and? - Mustang Evolution
Old 12-12-2011, 05:45 AM   #1
in first gear when stopping and trying to take off and putting it back in first i kind of doesn't want to take the shift. I got a 2001 mustang gt and recentley put a new clutch in it less than 600 miles..can anyone help me out?? thanks
finley is offline   Reply With Quote
Old 12-12-2011, 06:05 AM   #2
did you put a new throw out bearing in when you changed clutch if not thats what it sound like to me if you did then i need some more detailed info
conroy is offline   Reply With Quote
Old 12-12-2011, 06:33 AM   #3
Possible throw out bearing, check the slave cylinder for low fluid, last but not least pressure plate replaced as well as clutch?
cedro is offline   Reply With Quote
11:43 PM
