Does a Cadillac converter have anything to do with a 2001 mustang starting? - Mustang Evolution
Old 12-12-2011, 01:45 PM   #1
I have a 2001 mustang and the cadallic converter was stolen... now my car does not want to start.. does that have anything to do with it?
Or if you know anything else that could be wrong please say..
quin is offline   Reply With Quote
Old 12-12-2011, 01:49 PM   #2
Well when you take out the "cat" you lose a significant account of back pressure. That could possibly be a reason
taurino is offline   Reply With Quote
Old 12-12-2011, 02:28 PM   #3
NO, but if you provide the sub-model I could give you a possibility! Is it a base model (3.8L V-6) or a GT (4.6L V-8)?
Darrence is offline   Reply With Quote
Old 12-12-2011, 02:51 PM   #4
Yes, "catalytic converter"
Whoever stole it may have torn out the oxygen sensors as well, which would explain a no start condition.
Bodua is offline   Reply With Quote
Old 12-12-2011, 03:43 PM   #5
It seems to be getting common now for people to steal catalitic converters as they are stainless steel. They take them to recyclers to get money for them.
I have put straight through pipes on mine and removed the cats, but it still runs. Maybe they have done something under the car that is causing it not to start. Have a look around underneath and see what you can find. Hope they did not destroy too much.
These thieves have done a lot of damage to a lot of cars locally here !
roch is offline   Reply With Quote
Old 12-12-2011, 04:33 PM   #6
it can. when converter got stolen the o2 sensor probably went with it. without that 02 sensor your computer wont know how much fuel to put into the engine to let it turn over. ever heard the term running lean? means not getting enough fuel (can cause alot of damage if your running lean)
lucca is offline   Reply With Quote
Old 12-12-2011, 05:26 PM   #7
No cause cadillacs are made by GM
a CATALYTIC CONVERTER however could
iddig17 is offline   Reply With Quote
Old 12-12-2011, 05:43 PM   #8
Catalytic Converter is the part you are referring to. I have no idea how it got stolen from your car, but you will have to get a new one installed. Just be sure to ask for the correct part.
buchanan is offline   Reply With Quote
2001 mustang
11:33 AM
