1999 mustang will not stay running unless I keep the foot on the gas..? - Mustang Evolution
Old 12-13-2011, 08:30 PM   #1
This is my son's car and I am trying to help him with it. I have not tried anything yet, please tell me where to start to diagnose the problem. Thanks, Cruz
booth is offline   Reply With Quote
Old 12-13-2011, 09:22 PM   #2
does the engine seem to run fine otherwise? if so check the idle air control valve.
colton is offline   Reply With Quote
Old 12-13-2011, 10:06 PM   #3
thats very general...could be the battery, or the throttle body, an O2 sensor, bad gas, leak in the intake/exhaust, water in the engine, bad seals, carbon build up, etc.
Best bet is run the car for a bit (few mins or longer), take it to WOT (redline) if it warms up then see if it fixes itself.
Edit: I see some of the other people have chimed in with part-replacement suggestions. Try running the car first, see if you can get your son to spot any weird things happening. No need to jump to replacing parts without a firm diagnosis on what the problem is, especially in a car that old.
Arleigh is offline   Reply With Quote
Old 12-13-2011, 10:24 PM   #4
It depends does it do it all the time? I had the same problem in my ford bronco and turns out it was a cracked block.. my guess would be start with the basics oil change spark plugs fresh gas check the gas lines makeshure its not leaking and def. Check the idling if its idling 2 low it will cause it to clunk out if u take the gas off. If u don't no how 2 do this take it to a local auto zone or advanced auto they can change the idling for u and if this doesn't work they can run a test for free u just gotta ask
birtingr is offline   Reply With Quote
Old 12-13-2011, 10:51 PM   #5
Ignore these people > Take it to a shop > Have them tell you what you need > Google the parts > Google how to replace that specific part > Fix it > Continues to give problems > Sell to mexican > $$$$
arlen44 is offline   Reply With Quote
Old 12-13-2011, 11:15 PM   #6
IAC needs remobed and cleaned
MAF may need cleaned or replaced
vacuum leak somewhere on engine, check all hoses for breaks, or one that came off somewhere
pcv system plugged, check hoses and pcv valve for restriction etc
chaakmongwi is offline   Reply With Quote
Old 12-13-2011, 11:39 PM   #7
it could be anything from a dirty air filter, dirty fuel filter, worn out throttle cable, spark plugs, or bad gas to name a few things. which engine is it?
iseabail is offline   Reply With Quote
Old 12-14-2011, 12:08 AM   #8
Its for sure the starter, if you take it to the shop it will be about$200 depending on the make/model.
gerald is offline   Reply With Quote
Old 12-14-2011, 12:43 AM   #9
Sell the car since the car is so old
Kermichil is offline   Reply With Quote
Old 12-14-2011, 01:21 AM   #10
its faulty in the injectors or the air intake has a problem no other reason
thormond is offline   Reply With Quote
1999 mustang
» Members Mustangs
Saleen
05saleen
Red
Red89
Add your Mustang
11:15 AM
