Would a 1998 mustang gt engine fit in a 1998 v6 engine bay? - Mustang Evolution
Old 12-14-2011, 06:15 PM   #1
If you're going to swap in a mod motor use one from a 2005 through 2010 Mustang GT. You will need to get the K-member from a 1996 through 2004 GT. It's preferable that you source an aftermarket K-member for weight savings. The V6 K-member will not accept the mounts for the V8 mod motor. Remember that you will have to get the wiring, EEC-V, V8 front suspension, fuel lines, transmission, and rear axle replaced for ones used in V8 models. The V6 has a weak 7.5 rear axle where as GTs and Cobras use an 8.8. There's a bunch of little things that need to be swapped, too, so, you'll want a wrecked donor car to scavenge from. Do it yourself. Don't pay a shop to do it and you'll save a bunch of money on that alone.
imported_Buster is offline   Reply With Quote
Old 12-14-2011, 06:19 PM   #2
Yes sir. But the time and money its gonna take for the swap will be more money then it would cost for a true v8 mustang. And the 1998 GT engine is a DOG. 210Hp... Should just swap a 05+ 4.6 in it. Or the new 5.0. But if it where me. Id save money while keeping your mustang and enjoy it until you have about 4grand saved then sell yours and get a GT
artzai is offline   Reply With Quote
1998 mustang
» Members Mustangs
89 gt
BAD CO.
"Julie"
BIG_K
Add your Mustang
10:09 AM
