Rpms get stuck at 2k why? - Mustang Evolution
Old 12-19-2011, 09:45 AM   #1
i have a 1996 mustang gt. just cleaned throttle body replaced egr and iac valves. my car is idleing better now but when i take the rpms past 2k on the way back down they get stuck right at 2k what sensor could be causing this now. i have no engine light on too>
Category
huntington is offline   Reply With Quote
Old 12-19-2011, 09:48 AM   #2
Maybe a sticking throttle cable, maybe a bad pcv valve, maybe a vacuum leak.
telfor is offline   Reply With Quote
Old 06-15-2013, 05:14 PM   #3
Frankinstang's Avatar
I was having the same issue on my GT. Try turning the screws in ur throttle positioning sensor like a tiny bit loose. The valve may be binding. If u rev it up after 2k will it come back down to idle slowly?
Frankinstang is offline   Reply With Quote
Old 06-15-2013, 05:28 PM   #4
Chasafire888's Avatar
I HAD the exact same problem a month ago!... For me the vacuum hose under the iac had a hole in it... It was a tiny hole and it didnt make any noise but it was causing the problem. Just check all your hoses!
Chasafire888 is offline   Reply With Quote
05:30 AM
