What changes do I need to make on a 2004 Mustang GT to install factory Saleen supercharger? - Mustang Evolution
Old 12-21-2011, 04:15 AM   #1
Wiring Harnesses? Computer? Pistons? Hood?
eljin is offline   Reply With Quote
Old 12-21-2011, 04:43 AM   #2
If the supercharger is a bolt on, then you need to make sure of a few things. One is going to be your exhaust. Make sure that the exhaust piping is large enough for the psi output. You may need to change your computer at a dyno due to a difference effecting sensors. If you place a supercharger in your car, I would definately place a cold air intake in as well.
auley is offline   Reply With Quote
Old 12-21-2011, 05:26 AM   #3
should have bought the supercharger as a kit from roush instead. comes with everything you will need and instalation mannual.
birkie is offline   Reply With Quote
Old 12-21-2011, 05:42 AM   #4
it all depends on how much boost you want to run, higher boosts will need forged low compression pistons and a high flow fuel pump along with larger injectors and remapped computer..
wylingford is offline   Reply With Quote
Old 12-21-2011, 06:09 AM   #5
british cars are the best!! FACT
berwynne is offline   Reply With Quote
2004 mustang
03:29 AM
