Coilovers - Mustang Evolution
Old 01-04-2013, 10:47 AM   #1
1lowGT's Avatar
Coilovers
I was on mmr and found front and rear coilovers and seemed cheap. I'm not sure if they are a full set with everything you need. Help anyone?
Old 01-04-2013, 11:52 AM   #2
Mile high JDF's Avatar
They are a sleeve type coil-over so you would need to buy the correct type of shocks to go with the kit.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-04-2013, 12:04 PM   #3
1lowGT's Avatar
What kind of shocks then.
Old 01-04-2013, 12:11 PM   #4
I would call up MMR. The description doesn't say.
Old 01-04-2013, 04:27 PM   #5
HellaFlush03's Avatar
I run UPR coil over sleeves on Strange shocks in the front with QA1 175 lbs springs. I wouldn't go over 175 lbs springs. Sleeves will also slide onto the stock shocks. The rears are a lil tricky if your running a solid rear axle. I'm running a IRS set up. I also run tubular lower control arms with no spring buckets in the front. Id pick up some camber plates also.
HellaFlush03 is offline   Reply With Quote
Old 01-04-2013, 05:37 PM   #6
1lowGT's Avatar
Any links to where I can find this
06:54 AM
