Dyno tuned - Mustang Evolution
Old 01-04-2013, 11:56 AM   #1
03fastblack's Avatar
Dyno tuned
If I get my car dyno tuned is it pointless to get an screen tuner afterwards.
03fastblack is offline   Reply With Quote
Old 01-04-2013, 03:20 PM   #2
Stang23's Avatar
You mean a handheld programmer?
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 01-04-2013, 03:28 PM   #3
Yes.
---------- Post added at 04:28 PM ---------- Previous post was at 04:27 PM ----------
Sorry, I didn't realize it said "screen" I meant sct
Old 01-04-2013, 03:35 PM   #4
Stang23's Avatar
Ya it's pretty much pointless because if you add mods that require a tune your going to have to have it dynoed and whoever dynos your car will just use there tuner. Email tunes is where you need the tuner.
340 RWHP
325 RWTQ
Old 01-04-2013, 03:54 PM   #5
Alright thanks man
Old 01-04-2013, 03:58 PM   #6
Stang23's Avatar
Alright thanks man
No problem
340 RWHP
325 RWTQ
Old 01-04-2013, 04:05 PM   #7
Mile high JDF's Avatar
If you do get a handheld then you can request that they load a couple different tunes. My buddy has that for different pulley sizes on his GT500.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-05-2013, 09:39 AM   #8
1lowGT's Avatar
If you have to dyno tuned for the existing mods and then add more mods without getting it retuned will that affect anything?
Old 01-05-2013, 09:49 AM   #9
Stang23's Avatar
Ya the car won't run right. Could run too rich or too lean which could be bad.
340 RWHP
325 RWTQ
Old 01-05-2013, 09:58 AM   #10
Depends on the mods you get done. If it's mild bolt-ons the computer should be able to handle whatever mod you installed.a new tune would just optimize it.
Old 01-05-2013, 10:14 AM   #11
1lowGT's Avatar
So if I were to get dyno tuned with cai or h and catback and then added tb/plenum would that be an issue
Old 01-05-2013, 10:15 AM   #12
Nope. A re-tune would help optimize it, but it's not necessary.
Old 01-05-2013, 10:33 AM   #13
cliffyk's Avatar
I have three tunes, one for each of the 2½ seasons we have here (Hot, friggin' HOT and Nice)--we are currently in the middle of Nice. The tunes are loaded in an 8-tune "chip" from Delta Force Tuning, along with the stock tune and a couple of tunes for lower octane fuel (for when I go too far North). They can be switched on-the-fly.
Delta Force chip, switch & burner
The Nice tune produces the most power, it was when running this tune that I hit 262/305 rwHP/lb-ft. It has very aggressive ignition timing and optimal AFR of 12.8:1 to 13.2:1 at WOT.
The Hot tune dynoed at 256/300. The timing is pulled back a couple degrees to accommodate the warmer ambient air (80° to 90°).
The HOT tune produces 252/295 with another degree of timing pulled, and AFR at WOT of 12.5:1 to 13:1. Both to deal with ambient temps of 90° to 110°+
I run 93 octane fuel year round.
So to respond to the OP's question, if you are content to have just one tune that was optimised with the car tied down on a dynamometer and at whatever temperature it happened to be on the day it was tuned, then you do not need a tuner--OTH if you want to have multiple tunes for multiple situations then get a tuner.
Old 01-05-2013, 02:07 PM   #14
Well said.
Old 01-05-2013, 02:21 PM   #15
1lowGT's Avatar
How much for all that stuff
Old 01-05-2013, 02:52 PM   #16
cliffyk's Avatar
The Delta Force Commando software, which includes the Special Forces software, flash programming interface, and one Commando template is $679 MSRP¹. Special Forces includes SF templates for all Ford's ''96 to '04, and two "bullets" which let you tune two cars simultaneously (more about SF here). Commando is their pro-level tuning software and comes with one template (others can be purchased). The Commando package includes everything need to create and edit tunes, and flash them to your PCM. The flash interface holds five tunes, and takes about three minutes to upload the tune to your PCM.
The chip and 8-position switch is $343 MSRP¹.
Programming the chip requires a chip burner that can be bought for $285 MSRP¹--or you can develop your tunes with Special Forces and Commando, send them to me or DF and we will burn them onto the chip and return it to you.
The tunes themselves cost nothing as I developed them myself...
¹ - I can arrange significant discounts from MSRP.
Old 03-04-2013, 12:47 PM   #17
1lowGT's Avatar
Sorry for bringing this back from a long time ago, but so really its about 1k for that stuff? for all of that i could have 8 different tunes for the car?
08:21 AM
