4.6 k member - Mustang Evolution
Old 01-05-2013, 09:35 AM   #1
Ponylove's Avatar
4.6 k member
I found a 4.6 k member out of a 99 gt, iwas wondering will it fit a 94-97 mustang? I know the rear ends are a little bit wider in the 99 an up but wasn't sure about the rest of the parts would interchange
Ponylove is offline   Reply With Quote
Old 01-05-2013, 09:41 AM   #2
1lowGT's Avatar
Why would you want to swap?
Old 01-05-2013, 10:40 AM   #3
cliffyk's Avatar
If it is an aftermarket K-member it should fit (check with the manufacturer), if it is a stock unit it may not...
Old 01-05-2013, 11:34 AM   #4
Ponylove's Avatar
Because its a 95 and the 4.6 don't bolt up.
Old 01-05-2013, 11:38 AM   #5
93slowstang's Avatar
Yes it will bolt up. May have to watch tire offset to prevent the tires from rubbing.
Old 01-05-2013, 02:34 PM   #6
Ponylove's Avatar
Well I set it in and it dosent drop in. I tried every witch way and that's wen I was told the 94 an 95 fit the 5.0 an the 96 an up are what fit the 4.6
Old 01-05-2013, 02:59 PM   #7
I meant the k member will bolt in.
Old 01-05-2013, 03:04 PM   #8
Ponylove's Avatar
Ok I appreciate it man. Just makin sure before I bought it. This guy is sellin me the gt k member with the arms, springs an shocks for $100. Didn't think I could pass that up haha
Old 01-05-2013, 03:11 PM   #9
Definitely not a bad deal at all.
03:44 PM
