Traction control light - Mustang Evolution
Old 01-05-2013, 04:23 PM   #1
Blackedoutpony's Avatar
So when I start my car first thing I do is I turn traction off. Well I went to turn it off and it didn't light up I checked the fuse nothing wrong with it. Anyone know what the problem could be?
Blackedoutpony is offline   Reply With Quote
Old 01-05-2013, 04:28 PM   #2
98vertgt's Avatar
The bulb might be burnt out.. Did you turn it off and try to get the wheels to spin?
98vertgt is offline   Reply With Quote
Old 01-05-2013, 05:09 PM   #3
Where would the bulb be? I was going to do that but I just had a brand new clutch put in today along with flywheel and clutch fork etc. trying not to beat on it right now lol
Old 01-05-2013, 05:11 PM   #4
98vertgt's Avatar
Oh true lol I'm not sure if its a single bulb but my 06 350 had a burnt out check engine light and we replaced it. Maybe someone else will chime in
Old 01-05-2013, 05:12 PM   #5
schmitty426's Avatar
U will have to pull the whole instrument cluster out and the bulbs are on the back of it, its an easy fix
schmitty426 is offline   Reply With Quote
Old 01-05-2013, 05:51 PM   #6
I have a 2000 and my traction light comes on next to my cigarette lighter. Would that make a difference?
Old 01-05-2013, 06:01 PM   #7
Yes it would lol I'm used to seeing it in the dash lol I don't think u can switch out those bulbs u would have to replace the whole switch other than that wait it out to break in Ur clutch and flywheel and try an spin em and go from there lol
Old 01-05-2013, 06:51 PM   #8
Mzilla's Avatar
I have my traction control programmed to be off when ever I start my car
Mzilla is offline   Reply With Quote
Old 01-05-2013, 07:40 PM   #9
I'm probably gonna be tempted to do a burnout tomorrow so I guess ill find out tomorrow lol. Thanks
---------- Post added at 09:40 PM ---------- Previous post was at 09:40 PM ----------
How did you do that?
Old 01-06-2013, 07:50 AM   #10
Mzilla's Avatar
I has my tuner program it to stay off
Old 01-06-2013, 08:00 AM   #11
ksrumbel's Avatar
Pop the panel off where the traction control switch is. The panel is held in by clips. It is really easy to remove. Put a hand on each side of the panel in front of your shifter and pull outward and kind of push together. When you pop the panel off, you can access you traction control switch. The bulb is on the side of the switch. It is tiny. You just turn the bulb out. This just happened to me. I'm pretty sure you will need to get the bulb at a dealer.
ksrumbel is offline   Reply With Quote
Old 01-06-2013, 10:51 AM   #12
Ok I see what you mean ill try replacing the bulb and see if that's the problem. But for now everytime I start my car I just hit the switch and traction is off I tested it by getting sideways. Thanks for the help
Old 01-06-2013, 10:53 AM   #13
ksrumbel's Avatar
Yeah I do the same thing. I have to get to the dealer to order a new bulb.
10:16 PM
