Speedometer drive gear (automatic) - Mustang Evolution
Old 01-06-2013, 05:13 AM   #1
Polar Bear's Avatar
Region: Asia
I'm now finding out:
The drive gear on Ford rear wheel automatic transmissions is machined into the output shaft. Changing the drive gear is impractical since it requires a new output shaft and transmission teardown. Most have 7 or 8 teeth.
So changing to 4.10 gear means the speedometer can't be corrected? 97 automatic.
Steve
Polar Bear is offline   Reply With Quote
Old 01-06-2013, 05:45 AM   #2
98vertgt's Avatar
You'll need this
http://www.americanmuscle.com/ford-s...tool-9410.html
98vertgt is offline   Reply With Quote
Old 01-06-2013, 06:07 AM   #3
Polar Bear's Avatar
Region: Asia
You have a 98? Did you upgrade gears? Using this do you still need the 30 tooth speedo gear?
Steve
Old 01-06-2013, 06:08 AM   #4
98vertgt's Avatar
You don't need the speedo gear just this box. And I upgraded my gears but haven't bought this yet but I'm planning on it.
Old 01-06-2013, 06:13 AM   #5
Polar Bear's Avatar
Region: Asia
Automatic? How difficult was it? What ratio you upgrade to? Speedometer off a lot?
Steve
Old 01-06-2013, 06:16 AM   #6
98vertgt's Avatar
Yeah I'm auto. I had 4.10s and went to 3.55s. The speedo was way off with 4.10s but I didn't do the swap my self. I wouldn't try to
02:37 PM
