Help me please - Mustang Evolution
Old 01-07-2013, 06:21 PM   #1
Speed_Mister's Avatar
Region: Arkansas
Help me please
So I've been having trouble for two weeks with no car because I washed my car with a power washer and my car shakes and struggles when press on gas at low rpm's like around 1500 rpm's and has loopy idle. Feels like I lost power. Some one please help I changed spark plugs what could it be MAF, COP, a sensor of some kind maybe coil wires? My batter is relocated to back so I didn't get it wet. Please help.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 01-07-2013, 06:29 PM   #2
1slosix's Avatar
any codes?
carving corners like a boss
Old 01-07-2013, 06:31 PM   #3
Sounds like you have a bad miss. I would start with cop
Cdbformula is offline   Reply With Quote
Old 01-07-2013, 06:33 PM   #4
Region: Arkansas
Originally Posted by 1slosix View Post
any codes?
No codes
Full Bolt Ons
370rwhp 470rwtq
Old 01-07-2013, 06:39 PM   #5
1slosix's Avatar
did you check all the wires and make sure the pressure washer didn't knock anything loose or off
Old 01-07-2013, 06:41 PM   #6
I had the same thing happen to me. Didn't use a power washer i used a hose. Long story short, ended up getting a coil pack wet, and it didn't throw a code right away either. If it does throw a code just change the coil pack from another cylinder and see if the code changes. Worked for me went and got a new coil pack for $50 from Ford
Jcastro7608 is offline   Reply With Quote
Old 01-07-2013, 06:44 PM   #7
Region: Arkansas
Thank you! I was hoping somebody was experience the same as me now ik was it one of the #1-#4 coils?
Full Bolt Ons
370rwhp 470rwtq
Old 01-07-2013, 06:51 PM   #8
well mine was like cylinder 5 or something. Code was basically cylinder 5 misfire more or less. so just switch with a cylinder you kno is still good and code should change. If your car is running that sh*tty then you should def. be throwing a code. If u have the money upgrade to an MSD pack
Old 01-07-2013, 07:09 PM   #9
Region: Arkansas
Ahh it doesn't run that bad just at low rpm's but glad that I know the problem it stressed me out I got some coils from a crown Vic but the metal flange's are to wide for the electrical connection so they don't fit. I thought they are supposed to fit?
Full Bolt Ons
370rwhp 470rwtq
Old 01-07-2013, 08:04 PM   #10
Mfore33's Avatar
I bought a coil from jegs just to keep in the trunk for emergencies and to test for other bad coils. I think it was like 17 or so. I know most people won't run these but one is great for cheap trouble shooting. If you find a bad coil then go buy a ford factory one cause they are better.
04:55 PM
