RPM PROBLEM - Mustang Evolution
Old 01-07-2013, 08:53 PM   #1
Slp_loudmouth's Avatar
RPM PROBLEM
my rpms got messed up =/. so does anyone know what rpm my car should be running at with 3.73 @70mph in 5th gear?
Slp_loudmouth is offline   Reply With Quote
Old 01-07-2013, 09:34 PM   #2
1996mustang's Avatar
About 2k cliffyk has a calculator for this on his webpage paladinmicro.com
Old 01-08-2013, 03:38 AM   #3
cliffyk's Avatar
You can calibrate the gauges using a 9V battery, here's how.
Here is a direct link to my "How Fast Can I Go in Each Gear?" calculator...
02:45 AM
