16 and still learnig - Mustang Evolution
Old 01-08-2013, 05:19 PM   #1
2003StangGT's Avatar
Region: West Virgina
Hello I'm 16 and have a 2003 mustang GT with vortech s trim, all bolt on, lift weight puck flywheel, 373s, and short throw shifted. Tuned professionally. 450HP 373RWHP
I've heard that if you push over 450HP you will throw rods with the 4.6 sohc. Is that true? And if not what are some things I could do to make it a little bit faster and make it get down the strip faster. Running 11.9 right now. Just anything that would help me or I should know please help. Had another 01 GT that I wrecked , hydroplaned. I'm 16 and still wanting to learn stuff tht I don't know. Pleas help me out. Thanks
2003StangGT is offline   Reply With Quote
Old 01-08-2013, 05:36 PM   #2
Mathew r Wright's Avatar
I don't think you need that extra hp especially with an 11.9' that's fast enough for now try upgrading suspension to lower that ET.
Mathew r Wright is offline   Reply With Quote
Old 01-08-2013, 05:40 PM   #3
Venomouz831's Avatar
Yeap suspension and tires
)02 Gt, Founder of WE2G
Old 01-08-2013, 05:41 PM   #4
1slosix's Avatar
Wow sign me up for your parents lol. No clue on your question...welcome to the site
carving corners like a boss
Old 01-08-2013, 05:47 PM   #5
I would not recommend the 450hp also. Maybe 440 max.
Old 01-08-2013, 05:48 PM   #6
You have pics of the beast
Old 01-08-2013, 05:52 PM   #7
Mile high JDF's Avatar
I wouldn't push that block much more until you can get a built bottom end. I would definitely do as the other guys said. A driver mod is another big thing. You could try shedding some weight as well.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-08-2013, 06:02 PM   #8
+10
Old 01-08-2013, 06:03 PM   #9
jleber123's Avatar
+1000000
jleber123 is offline   Reply With Quote
Old 01-08-2013, 06:40 PM   #10
v8pony's Avatar
+10000
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-08-2013, 06:41 PM   #11
zinc_yellow's Avatar
Region: New Mexico
Originally Posted by njstanger View Post
+10000
+10000000000000000000000
zinc_yellow is offline   Reply With Quote
Old 01-08-2013, 07:00 PM   #12
2300turboford's Avatar
Just practice planting the power to the ground
Old 01-08-2013, 07:26 PM   #13
ksrumbel's Avatar
You should just plain practice driving. You've wrecked one already. And I would assume it wasn't as modified as your current one. I would say a stock mustang could be a handful for a younger driver. The more seat time you have in the car, the quicker you will learn the limits of both the car and yourself.
ksrumbel is offline   Reply With Quote
Old 01-08-2013, 07:27 PM   #14
v8pony's Avatar
+10000
2002 5spd GT
Old 01-08-2013, 08:02 PM   #15
Speed_Mister's Avatar
Region: Arkansas
Hahah nice stang if you ran a 11.9 in 1/4 mile. To prevent throwing a rod or piston you could get stronger pistons and rods, a built bottom end kit. Speed shifting, slicks or drag radial, or wide street tires like nittos like 315's and skinny tires which are 4 inches wide up front or just get 245 street tires or 275 up front. Shedding weight like bumper supports put battery in the back trunk
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 01-08-2013, 08:47 PM   #16
1996mustang's Avatar
Im still waitin on pics of the car.
Old 01-09-2013, 05:09 AM   #17
Thanks for all the help. And I'm not that bad of a diver, raced stock cars a lot when I was younger and the last mustang I wrecked was because if driving fast in the rain witch won't happen agian lol
Old 01-09-2013, 05:13 AM   #18
Here's the pics
ID:	84823   Click image for larger version
Old 01-09-2013, 05:17 AM   #19
It's not me, it's you.
primer2tone's Avatar
Is the suspension stock?
Old 01-09-2013, 05:21 AM   #20
Yes, has a kenne brown sup frame.
Would lowering spring and new sway bars help make it handle a little better and make it a little faster?
---------- Post added at 06:21 AM ---------- Previous post was at 06:21 AM ----------
And how much would it cost for a forged bottom end? And forged rods and pistons and how much horse could I push then?
Old 01-09-2013, 08:30 AM   #21
at 450hp at the motor you are in the area where the tune REALLY matters.... it has to be spot on and you cant just have a mail order tune and be good to go. The tune would also have to be done by someone that knows what they are doing and tune it for daily driving duty. Sure you can get more hp/tq with more timing but why not dial it back a couple and have wiggle room.
Also its ALL about how its taken care of, if you beat on it every day bad things will happen. I think under 400rwhp is ok but might be best to pull some power out of it and keep it a bit richer to stay on the safe side.... rebuilding a motor is not cheap.
Old 01-09-2013, 08:40 AM   #22
Yes it was professionally tuned and has 49,000 miles
Old 01-09-2013, 08:43 AM   #23
maldog's Avatar
Region: Nevada
Be responsible and safe with that amount of HP under your ***. Welcome to the forum.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 01-09-2013, 09:38 AM   #24
98vertgt's Avatar
Here's the pics
Lower that beast!
98vertgt is offline   Reply With Quote
Old 01-09-2013, 09:40 AM   #25
good, you happen to have the dynograph along with a/f and the timing used etc?
Old 01-09-2013, 10:57 AM   #26
Yes get lowering springs and arms as well as tires so you can lower you're 1/4 and 60'
Old 01-09-2013, 11:03 AM   #27
Alright thanks
Old 01-09-2013, 11:05 AM   #28
AgentOrange's Avatar
If the motor is safe where it's at, then invest elsewhere. Relocate the battery, get a chromoly k member and coilovers, subframe connectors and new rear control arms... it's not all about numbers.
AgentOrange is offline   Reply With Quote
Old 01-09-2013, 11:44 AM   #29
Midnight's Avatar
What I could've said already was said above. Welcome and be safe. THINK!
Midnight is offline   Reply With Quote
Old 01-09-2013, 12:01 PM   #30
Sway bars aren't necessary for a drag car. Your best bet would be to find some drag race springs and shocks because they will help keep the weight focused more on the rear to help you get traction out of the hole. Companies like Maximum Motorsports make a great package for drag racing that includes dang near everything you would need in the suspension area.
A forged bottom end would cost as much as you want it to. The easiest way would be to buy a shortblock/longblock from companies like DSS Racing or Modular Mustang Racing. I cant remember what their kits start off at but I believe it's somewhere in the $3K range. They make shortblocks rated to certain power levels. Or you could piece together your own engine if you would rather save a little money by doing it yourself. Those companies also sell forged rotating assemblies. You could also try looking for an 03-04 Cobra bottom end.
Old 01-09-2013, 01:36 PM   #31
Matticus's Avatar
This might be of interest if you are wanting forged internals, otherwise suspension is half the battle. If you don't hook up, power is pointless.
ID:	84893   Click image for larger version
Matticus is offline   Reply With Quote
Old 01-09-2013, 01:38 PM   #32
Matticus's Avatar
If you're serious about it though, a forged crank would be even better, the crank in that kit is cast iron I believe, but it really depends on your budget and goals.
Old 01-10-2013, 07:50 AM   #33
CodyNelson's Avatar
That's only a 600hp setup, a cast crank will be more than adequate for that kind of power.
And welcome! My best advice to a 16 yr old with that kind of power is park it and get a beater to drive. As much as you don't want to hear it, you're 16 and you're going to wreck (probably more than once) so PLEASE tear up a civic or even a v6 and don't destroy all the money and time already put into that beauty. I'm only speaking from experience. I'm 22 and have a vortech blown GT and almost destroyed my entire investment in a split second because a deer jumped in front of me and I slid over through a ditch. Having to go back and look at all the money wasted, and then having to replace all the components that got messed up was complete torture on me and my wallet. If you keep driving it all the time, my advice is take it easy and learn your car. I know its hard to keep that right foot from hitting the floor, but learning what you car does and reacts like in different situations is key. Don't try to be Superman, Clark Kent is cool enough lol
Ok, I'm done sounding like an old man. That's a sweet car and I look forward to seeing more of it
Old 01-10-2013, 09:18 AM   #34
Thanks man and I understand completely where your coming from
Old 01-10-2013, 10:05 AM   #35
95v686gt's Avatar
Couldn't of said it better myself but I'm with spec on what he asked. Did you get the print out from the dyno on a/f ratio's timing used etc?!
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
04:30 AM
