P1152 - Mustang Evolution
Old 01-09-2013, 05:49 PM   #1
truckinu's Avatar
P1152
Whatever this code is, its making my car run like crap. I thought water might have gotten to the air filter since its been raining. Pulled it out and its dry. Any other thoughts?
truckinu is offline   Reply With Quote
Old 01-09-2013, 05:58 PM   #2
tc x 4's Avatar
Has to do with the 02 sensor on bank 2. Just Google it for the details
Old 01-09-2013, 07:00 PM   #3
98GTCONV's Avatar
Does it make your car idle funny and want to bog down?
98GTCONV is offline   Reply With Quote
Old 01-09-2013, 07:25 PM   #4
tc x 4's Avatar
Yes, it can do a lot of things. Orielys will read your code and give you a printout for all the possible problems.
Old 01-09-2013, 07:27 PM   #5
98GTCONV's Avatar
Mine does that after being driven a lot.
Old 01-09-2013, 09:52 PM   #6
1996mustang's Avatar
truckin when did it start doin it, and just in case after what did u install or do to the car before it started doin it?
Old 01-10-2013, 07:23 AM   #7
truckinu's Avatar
It started tuesday afternoon. I haven't done anything to the car since I put the x pipe on a month ago.
I thought maybe something got wet but its not raining today and it still doing it.
---------- Post added at 09:23 AM ---------- Previous post was at 09:21 AM ----------
Yes kind of. Feels like I've got a cam in it but sounds terrible. When I smash the gas it runs fine its just at idle and part throttle when its happening you can feel the jerkiness.
Old 01-10-2013, 11:04 AM   #8
98GTCONV's Avatar
Yep that's what mine does. My shop said it was bad O2 sensors. For now I just reset my computer and it runs fine for a while.
Old 01-10-2013, 11:26 AM   #9
cliffyk's Avatar
Here is what the shop manual says about P1152, same possible causes as P1130.
It is for bank 2 sensor 1, I would first suspect a wiring problem--you need to get under there and see what things look like. A dead or dying O² sensor will read as "stuck lean", not stuck rich...
Old 01-10-2013, 12:28 PM   #10
Lorraine's driver
ab_mach1's Avatar
FYI for the ME Community, we have an article that has the Ford OBD-II codes.
Ford OBD-II Trouble Codes
Instagram: @ab_mach1
Old 01-10-2013, 01:11 PM   #11
tc x 4's Avatar
Good info.
Old 01-11-2013, 09:38 AM   #12
truckinu's Avatar
Are o2 sensors interchangeable? In terms of can I take the back one and move it to the front? Different part numbers and the plastic on the plug is a different color.
Old 01-11-2013, 09:40 AM   #13
Lorraine's driver
ab_mach1's Avatar
I'm not sure. I noticed mine were different color too. I'm guessing no, since both of us found some differences.
Old 01-11-2013, 09:42 AM   #14
truckinu's Avatar
Boy your full of good news. Didn't want to hear that...lol
Old 01-11-2013, 09:49 AM   #15
Lorraine's driver
ab_mach1's Avatar
Doh! Lol, sorry
Old 01-11-2013, 10:18 AM   #16
cliffyk's Avatar
They are functionally the same, the only difference is in the locating keys on the connector, which can be cut off if needed to put a rear sensor on the front, or swap the rear sensors:
Old 01-11-2013, 12:36 PM   #17
tc x 4's Avatar
I don't think so. I had trouble with my tune when I installed headers, and they ask me if I put the rite sensors back in.
Old 01-11-2013, 06:51 PM   #18
truckinu's Avatar
This worked. I just cutoff the key ways and its running as it should. Thanks for the help.
Old 01-11-2013, 06:57 PM   #19
cliffyk's Avatar
Cool...
As stated they are all just plain ol' PZ (Platinum/Zirconium) narrowband O² sensors--read more about those here--the connectors are different to make sure they don't get connected incorrectly on the assembly line--it's idiot proofing to make sure the average UAW worker can handle it...
11:39 PM
