Off/Road X Pipe Project - Mustang Evolution
Old 01-09-2013, 08:06 PM   #1
Sonicblue11's Avatar
Hey guys I finally found the time to put my o/x pipe on tmmrw but should I be aware of any problems before I start this tmmrw? Let me know thanks
Sonicblue11 is offline   Reply With Quote
Old 01-09-2013, 08:13 PM   #2
Supe01stang's Avatar
Which brand?
---------- Post added at 10:13 PM ---------- Previous post was at 10:11 PM ----------
Do you have PB blaster? Spray it on the day before on all the bolts.
Supe01stang is offline   Reply With Quote
Old 01-09-2013, 08:17 PM   #3
Originally Posted by Supe01stang View Post
Which brand?
Yeah I already soaked the bolts with pb and wd and it's a upr
Old 01-09-2013, 08:18 PM   #4
I was going to do my BBK o/r X pipe last week and I'm glad I didn't do it. First it's cold here in NY to do it on the street. So I took it to a shop and had them install it. The bolts had to get really heated with a torch for a while. My mechanic said I would of snap those bolts because they was a pain. It cost me only $105 and I'm good with tools.... Kind of.
ID:	84953   Click image for larger version
Old 01-09-2013, 08:20 PM   #5
Ok. The passenger side was the pain.. That was it! The rest was a cake walk. You should be fine
Old 01-09-2013, 08:23 PM   #6
See that's what I'm afraid of, snapping the bolts on the manifold, did they hear those ones?
Old 01-09-2013, 08:23 PM   #7
Matticus's Avatar
Don't forget to unplug the battery. You'll be close to the starter and you'd be in for a "shocking" surprise if you got against it. Also, you may not need them if you don't have a lot of miles, but if you are like I was, it wouldn't hurt to replace o2 sensors while under there. I never had a problem with them until they were taken out and plugged back in. I was running rich enough to get like 8 mpg. But this may or may not apply to you.
Matticus is offline   Reply With Quote
Old 01-09-2013, 08:24 PM   #8
What's your catback?
Old 01-09-2013, 08:25 PM   #9
Matticus's Avatar
If you do get o2 sensors, don't get universal fit ones, get some good ntk ones or oem if you don't want to spend as much, just make sure they are made just for mustangs.
Old 01-09-2013, 08:29 PM   #10
Thats the one I'm talking about in the manifold.
---------- Post added at 10:28 PM ---------- Previous post was at 10:25 PM ----------
I bought the mil eliminator s from AM and have no problems yet. It's been 1 week so far
---------- Post added at 10:29 PM ---------- Previous post was at 10:28 PM ----------
Sonicblue11 what catback you running?
Old 01-09-2013, 08:31 PM   #11
I'm running slp lm1 and I also have the mil eliminators, me Nd my buddy are start tmmrw at like 7am
Old 01-09-2013, 09:43 PM   #12
Allans03ragtop's Avatar
I broke one of my bolts off on the drivers side. Man it sucks to have to drill out the old bolt from under the car. We did get it done though. It is a piece of cake if you don't run into any problems like that. It is a little tricky getting to the front o2 sensors to unplug but it can be done with a long screwdriver. Now here is something you will not like. I used 18mm non fouler plugs that cost 3.99 at the local auto parts store to solve the service engine light instead of the 69.95 MIL eliminators. All you have to do is drill them out with a 1/2 inch drill bit so the o2 sensor will fit in it. Then just screw the non fouler plug in where the o2 sensor goes then screw the o2 sensor into it plug them back in and you are good to go. What this does is move the o2 sensor back out of the fumes so it thinks there are cats still in place. This is for the back o2 sensors not the front ones.
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 01-10-2013, 01:03 AM   #13
Venomouz831's Avatar
Extensions will help
)02 Gt, Founder of WE2G
Old 01-10-2013, 02:56 AM   #14
wolfstang03's Avatar
Where in ny? I'm in rochester
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 01-10-2013, 11:55 AM   #15
The bolt on the manifold broke now idk what to do
Old 01-10-2013, 12:00 PM   #16
Mine did too on the passenger side. That was just a reason for me to get headers and bring it to the shop for the install. I didn't have.the.patience or the time to drill and possibly have.to re-tap the manifold.
--WOLFSTANG 03--
Old 01-10-2013, 12:08 PM   #17
Lorraine's driver
ab_mach1's Avatar
I'm surprised a shop would install an off road X or H, since there are no cats. Did you have to sign off on anything?
Instagram: @ab_mach1
Old 01-10-2013, 12:13 PM   #18
1996v6stang's Avatar
Yeah especially since ny has emissions n ****
1996v6stang is offline   Reply With Quote
Old 01-10-2013, 12:17 PM   #19
Lorraine's driver
ab_mach1's Avatar
Do you think you can drill out the broken bolt or stud? Which side was it that broke? If you can drill it out, you can probably borrow a tap & die set from a local auto parts store and tap it out for a new bolt.
Old 01-10-2013, 12:23 PM   #20
My friend owns a shop where I had my headers and off road pipe put on. I had the mil eliminators but they failed within a month so now I just use my tuner to clear the code and have it inspected.
--WOLFSTANG 03--
Old 01-10-2013, 12:39 PM   #21
The bottom driver side bolt broke on the bottom but it broke halfway, how did yous get the bottom passenger side bolt off? It seems impossible
Old 01-10-2013, 12:45 PM   #22
You will need a universal joint for your ratchet to get that one iff
Old 01-10-2013, 12:54 PM   #23
Seriously?
Old 01-10-2013, 12:54 PM   #24
Lorraine's driver
ab_mach1's Avatar
Plus an extension. Actually, I think I used 2, 6" & 2" as well as the u-joint.
Old 01-10-2013, 12:56 PM   #25
JetLife 01GT's Avatar
Seriously?
Yep. Universal joint socket is the only way to get it off. That and a little patience. I did mine a few months back. Also if you have an impact that'd help out a lot
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-10-2013, 12:57 PM   #26
Yes you need extensions and good luck with the broken boat
Old 01-10-2013, 12:57 PM   #27
I used two 10" extensions
2001 GT
Old 01-10-2013, 01:53 PM   #28
This is the bolt and I went and got a ujoint but it's not budging
Old 01-10-2013, 01:59 PM   #29
Can you say torch and vice grips
Old 01-10-2013, 02:09 PM   #30
Yeap that's if you can get vice grips in there
Old 01-10-2013, 03:16 PM   #31
Lorraine's driver
ab_mach1's Avatar
Spray that thing again with PB blaster and let it set 15 minutes. Get it good and soaked.
Old 01-10-2013, 03:35 PM   #32
It's the stud that's stuck in the manifold now how the hell does that come out? Drill it out? And all the other ones came out good with heat and pb
Old 01-10-2013, 04:26 PM   #33
Lorraine's driver
ab_mach1's Avatar
The studs stay on the manifolds. Just the nuts run out.
Old 01-10-2013, 04:28 PM   #34
So what's sticking out is just the bolt in the stud in the mani?
Old 01-10-2013, 04:32 PM   #35
Lorraine's driver
ab_mach1's Avatar
Two on each side, is what you see, right? Your x pipe flanges should fit up to it. I guess you should say it's really a threaded stud, not a bolt.
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
10:51 AM
