procharger or turbo charged - Mustang Evolution
Old 01-10-2013, 07:06 AM   #1
Justin1998GT's Avatar
I have a 4.6 4v aluminum block out of a Lincoln mark 7 and I need to know which I should buy pro charger or turbo its going in a 1998 gt
Justin1998GT is offline   Reply With Quote
Old 01-10-2013, 07:28 AM   #2
CodyNelson's Avatar
Region: West Virgina
There are a million different variables to consider when choosing to go forced induction. Before we can tell you what you would be happiest with we need to know more details about the car/plans you have for it. Is this going to just be a mild street car or full blown drag car? What type suspension setup do you have (Tubular k member and front end is required for turbos)? Are you going to get better internals? How much power do you want to make (be realistic)?
Old 01-10-2013, 07:47 AM   #3
All I know is its an eibach sportline its will just be used for everyday car but want some power when I need it. Right now it has slotted and drilled rotors cobra calipers 3.73 rear end tk 600 tranny Hurst short shift. 315/35zr 17 in back and 275/40r 17 in front for tires getting list of parts in motor soon
Old 01-10-2013, 07:56 AM   #4
CodyNelson's Avatar
Ok if its going to be a street car and you don't have a tubular suspension already then go with the procharger. The internals of the motor is key to how much power you can run. And most people mess up and think its just the crank, rods, and pistons are what important, but fail to realize that the hardware used to put everything together is just as much if not more important to how far you can push it. Find out the internals along with what kind of main studs, rod bolts, head bolts, etc. were used if it has been rebuilt
Old 01-10-2013, 08:00 AM   #5
Its being rebuilt by my dads friend a former mechanic for nascar now working for ford. told him I wanted 500 horse at flywheel told him to do his thing with torque.
Old 01-10-2013, 10:16 AM   #6
95v686gt's Avatar
Make damn sure it gets forged crank and rods. Lincoln mark viii's were cast cranks. And like Cody said it needs the proper hardware holding it together too. ARP is a good place to get that. Still what year Lincoln block?
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 01-10-2013, 11:29 AM   #7
No idea I'll get that info
Old 01-10-2013, 11:33 AM   #8
2300turboford's Avatar
Turbo makes more power on the same amount of boost proven fact
Old 01-10-2013, 01:00 PM   #9
Thanks for info
Old 01-10-2013, 01:06 PM   #10
CodyNelson's Avatar
True. But turbo installs are much more in depth, turbo kits are much more expensive, and he would have to completely change his whole suspension up front. You may make more per lb of boost but if 500hp is all he is wanting then why spend 3 times the money to just say "Oh well I'm running 2 psi less than you are"? Just get a blower and run a little smaller pulley
Old 01-10-2013, 01:10 PM   #11
On3 performance 2k dollars why would he change his suspension? And install is easy have u ever put a turbo kit on?
Old 01-10-2013, 02:35 PM   #12
onesickstang01's Avatar
The basic kit is 2k. Then add kmber and tubular arms. Not sure if the basic kit even Includes injectors or fuel pump or mass airflow sensor. And its a much more difficult install than a blower
onesickstang01 is offline   Reply With Quote
Old 01-10-2013, 03:12 PM   #13
sam minnick's Avatar
There are alot of supercharged stangs out there do something a little different thats what im doing... TURBO LOL
sam minnick is offline   Reply With Quote
Old 01-10-2013, 03:17 PM   #14
On3 sells the tubular k member and full suspension for 650
Old 01-10-2013, 04:10 PM   #15
Redstang1's Avatar
I know nothing about the on3performance but the single turbo kit from American muscle is almost 6k. A turbo kit for 2k probably isn't worth buying but that is just my humble opinion but I've found that the cheap way is frequently the worst/wrong way
Redstang1 is offline   Reply With Quote
Old 01-10-2013, 04:20 PM   #16
I've seen em and there worth buying my friend is building one
Old 01-10-2013, 04:29 PM   #17
Matticus's Avatar
I've been told the product itself is fine, but I've seen numerous reports of missing essential parts.
Matticus is offline   Reply With Quote
Old 01-10-2013, 04:35 PM   #18
CodyNelson's Avatar
The on3 kit is more than 2k and the turbo, wastegate and BOV with their kits are junk. The piping is fine. And he has to do suspension work because the turbo kits won't fit around the stock k member
Old 01-11-2013, 10:29 AM   #19
95v686gt's Avatar
Buy 2 leaf blowers and pipe them in. That's different LOL.
Old 01-11-2013, 11:39 AM   #20
For the low price you can upgrade the turbo and the fuel system bov and be under some of the other kits
Old 01-11-2013, 11:42 AM   #21
95v686gt's Avatar
Just depends on your budget. I'd love to have the hellion kit! :drool:
Best of both worlds!!!!!
Old 01-11-2013, 12:44 PM   #22
2003mustangGT's Avatar
Go turbo!!! You wot regret it!
2003mustangGT is offline   Reply With Quote
Old 01-11-2013, 03:27 PM   #23
taylor98gt's Avatar
My friend had a on3 kit on his fox he didn't have Any problems.with his.
taylor98gt is offline   Reply With Quote
Old 01-11-2013, 08:38 PM   #24
AgentOrange's Avatar
I'll go against the grain and recommend Vortech. Cheapest route, still quality stuff, V3 requires no tapping of the oil pan and blower oil isn't very expensive, good power for stock internals, fuel management is provided with kit along with a voucher for a base tune (means no towing to your tuner!), cxracing makes an intercooler kit that you can integrate down the road if you want more power at the same boost. Then everyone died. The end.
AgentOrange is offline   Reply With Quote
Old 01-11-2013, 10:58 PM   #25
CodyNelson's Avatar
I own and LOVE my vortech. I have no issues with this lol
04:06 PM
