Dose anyone have hood pins on the stock hood? - Mustang Evolution
Old 01-10-2013, 10:38 AM   #1
Rich04's Avatar
While my car was at the body shop i had some hood pins i knew the owners so i asked them if they can put them on for me they said they'll do it for free then when i went to pick up the car about a week later i didn't see them on and i asked they said the hoods fiberglass underneath and it will crack from vibrations they told me to come back if i find a way around, like a bushing or something any ideas?
Rich04 is offline   Reply With Quote
Old 01-10-2013, 10:42 AM   #2
SoCalKev's Avatar
Send a message via Skype™ to SoCalKev
Why hood pins? Just for the look or do you really need them?
---------- Post added at 09:42 AM ---------- Previous post was at 09:39 AM ----------
Guess that really doesn't matter you may have to move them towards the edge of the hood. So while drilling it will have more support and it won't be to noticeable
SoCalKev is offline   Reply With Quote
Old 01-10-2013, 10:43 AM   #3
Rich04's Avatar
Pretty much just the look, but also cause i forgot to fully close my hood an it started shaking as i was driving then i realized it wasn't closed.
---------- Post added at 12:43 PM ---------- Previous post was at 12:42 PM ----------
I was having the shop place them at the best spot for support they agreed and then told me i need something els so the fiberglass wont crack from vibrations.
Old 01-10-2013, 10:50 AM   #4
sam minnick's Avatar
I have hood pins in my stock hood and never had a issue.. most hoods that are pined down are fiberglass... my old car had a six inch cowl and that was a pin on hood i didnt have any problems with that either.. when i get off work ill take a few pics and post them and you can see how mine are done and look
sam minnick is offline   Reply With Quote
Old 01-10-2013, 10:51 AM   #5
Rich04's Avatar
Thanks! That would really help
Old 01-10-2013, 01:20 PM   #6
I found one oic so far
Old 01-10-2013, 01:23 PM   #7
Rich04's Avatar
No cracks underneath right?
Old 01-10-2013, 01:55 PM   #8
Small paint chip around the hole on the inside but no cracks and the whole hood is fiberglass
ID:	85082   Click image for larger version
Old 01-10-2013, 02:26 PM   #9
Aggiesrok's Avatar
If you're keeping your orginal hood catch and still using it, then the hood pins don't need to be super tight and they aren't fully holding down the hood. The chrome trim ring on top should displace the force across the hood. I don't understand why they think it will be a problem.
Old 01-10-2013, 02:34 PM   #10
Rich04's Avatar
Thanks for the pictures. And yeah idk im gonna go back there and have then install them or ill end up doing it myself. Thanks guys
Old 01-10-2013, 02:37 PM   #11
Venomouz831's Avatar
Do it yourself it's easy took me 2 hours
)02 Gt, Founder of WE2G
Old 01-10-2013, 02:54 PM   #12
Mine has the original latch but i dont have to pop my hood to open it.. i push down pull the pins and then unlatch it in the center
Old 01-10-2013, 03:18 PM   #13
Horseplay's Avatar
does hood pins help close the hood better? for some reason my hood doesnt close perfect and wen im going 75 in the highway it shakes.
Low2v
Old 01-10-2013, 03:20 PM   #14
It does help my hood doesn't shake at 100 plus
Old 01-10-2013, 03:20 PM   #15
Rich04's Avatar
Yeah but if im getting if done for free ill take that then worrying if i mess up
Old 01-10-2013, 03:26 PM   #16
Horseplay's Avatar
sick i gota look ino buying this! does AM sell it or where do i buy it
Low2v
Old 01-10-2013, 03:48 PM   #17
They were on my car when i bought it so im not sure where to get them
Old 01-10-2013, 04:40 PM   #18
Polar Bear's Avatar
Region: Asia
AM has them. They also have the dress up ones that just stick to the top of your good.
Steve
Polar Bear is offline   Reply With Quote
Old 01-10-2013, 04:46 PM   #19
Horseplay's Avatar
thanx i needa check it out
Low2v
05:48 PM
