About ready to do the Rear end - Mustang Evolution
Old 01-11-2013, 05:41 AM   #1
03RedfireGt's Avatar
Ok so, I am sure the differential is bad in the pony. I am going to change it. Since I am having that done I figure I might as well add 3.73 gears. Question is AM has a ring an pinion install kit an a rear end install kit. Which one will I need. The price difference isn't to bad but when you figure in gears, differential, the install kit, gear oil, stabilizer, an a chrome cover just because, plus labor. I am looking probably at about 700 +. So I am trying to cut that price down a bit.
03RedfireGt is offline   Reply With Quote
Old 01-11-2013, 10:06 AM   #2
lee1rbc's Avatar
I would go with the Ford racing gears and install kit at AM for 259.99. Your bearings are probably the problem. This kit includes everything needed and royal purple so you dont need stabilizer.
lee1rbc is offline   Reply With Quote
Old 01-11-2013, 10:20 AM   #3
Site Sponsor
Sponsor
AMWill's Avatar
03RedfireGt,
As already mentioned above, I would get the whole Ford Racing Gears/install kit. It will come with everything you need to replace the gears and new bearings. The factory gears are pretty old being it's a new edge Mustang, so if they aren't the current issue, I'm sure it's only a matter of time. That being said, you may also need new carbon disc's if the factory rear discs are burnt out. You can get new discs or a new HD Track-lock differential, either one is wise while you have diff apart.
Hope this helps!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-11-2013, 10:26 AM   #4
wolfstang03's Avatar
Look into the trac rebuild while you're redoing everything. The clutch packs are much thicker and stronger
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 01-11-2013, 11:26 AM   #5
I am just going to buy a whole new differential, at least that was the plan rather than doing a rebuild. AM has one for 249.99. Is that the better option you think. I seen the combo kit with gears, install kit, oil an stabilizer. I will pick that up with the differential.
---------- Post added at 12:26 PM ---------- Previous post was at 12:23 PM ----------
Do you think it is just the bearings an not the differential? I would hate to put her in the shop an have them tear it apart only to find out I need a new differential.
Old 01-11-2013, 11:49 AM   #6
Thanks for you help, i will just order a new differential an the combo kit. That way its all done. Thanks again for your help. You guys rock
Old 01-15-2013, 03:35 PM   #7
Site Sponsor
Sponsor
AMWill's Avatar
03RedfireGt,
Good call! This way there will be no surprises when the diff is taken apart. Plus, you're starting over with practically a brand new stronger rear. I'm glad we could help out too!
Shane
Old 01-15-2013, 06:13 PM   #8
jjsg09's Avatar
Not trying to take business from AM but this is a good kit for the money. Maybe AM can match you this set for the price.
http://www.latemodelrestoration.com/...r-End-Gear-Kit
Old 01-16-2013, 05:02 PM   #9
Site Sponsor
Sponsor
AMWill's Avatar
Ford Racing Mustang 3.73 Gears 8.8 (86-09) M-4209-88373 at LRS - Free Shipping!
No worries, we actually have these same parts available for the same price, including shipping. Check it out on our site!
Shane
Old 01-16-2013, 06:06 PM   #10
jjsg09's Avatar
Shane
Oh Snap! I'm sorry didn't see it. That's awesome though.
Old 01-17-2013, 04:50 PM   #11
Site Sponsor
Sponsor
AMWill's Avatar
Not a problem, I just wanted you to be aware of it in case you ever needed a gear kit!
Shane
05:16 PM
