Exaust - Mustang Evolution
Old 01-11-2013, 09:10 PM   #1
New me's Avatar
Exaust
I have a 96 gt and I can't get the h pipe off and I broke off one of the bolts and I can't get to the manifold how do u get to it
New me is offline   Reply With Quote
Old 01-11-2013, 09:15 PM   #2
2300turboford's Avatar
Torch maybe idk
Old 01-11-2013, 09:25 PM   #3
Trbluebullitt's Avatar
New headers maybe depends on how close it broke off and you might can drill it out
Trbluebullitt is offline   Reply With Quote
Old 01-12-2013, 06:15 AM   #4
JetLife 01GT's Avatar
So your h pipe is still on? Where did the bolt break at? If it broke off up by the flange, you should be able to take the nuts off of the other bolts then pull the h pipe off. Then you can access the broken bolt. Possibly drill it out or use vice grips with a torch to screw it out. Now if the bolt broke off before the nut. Should be able to just take that nut off, unbolt the rest, drop h pipe then get that bolt out. You can buy new manifold studs at auto parts store or use an actual bolt from a hardware store. But getting the h pipe off is the best way to get to the manifold
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
01:19 PM
