2000 Gt clutch question - Mustang Evolution
Old 01-12-2013, 07:17 AM   #1
DeVellis's Avatar
So randomly my clutch seems a lot easier to push now is this a warning sign for something going bad in the clutch itself or is it my transmission?
DeVellis is offline   Reply With Quote
Old 01-12-2013, 01:22 PM   #2
Mile high JDF's Avatar
It's probably your clutch quadrant. Do you have an aftermarket clutch? Take a look at your clutch pedal under the dash. Look for a white half moon plastic piece. There should be teeth on the outer edge, see if those look worn down.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-12-2013, 01:30 PM   #3
DeVellis's Avatar
Yeah I do have an after market ford racing clutch.
Old 01-12-2013, 01:33 PM   #4
It's probably your quadrant. The stock set-up doesn't react well to heavy pressure plates. American Muscle sells aftermarket set-ups that deletes the quadrant and runs a firewall adjuster instead.
Old 01-13-2013, 05:45 AM   #5
DeVellis's Avatar
Where is this piece at I don't see it.
Old 01-13-2013, 08:39 AM   #6
DeVellis's Avatar
Now I hear a rattling coming from underneath my car.. Could it still be the quadrant ?
Old 01-13-2013, 12:47 PM   #7
It should be mounted on a shaft somewhere above your gas pedal. Where does the rattle sound like it's coming from?
Old 01-13-2013, 12:50 PM   #8
DeVellis's Avatar
The rattling is coming from underneath and when I push in my clutch it goes away.
Old 01-13-2013, 01:08 PM   #9
Is it extremely loud? That is probably something more clutch related.
Old 01-13-2013, 10:12 PM   #10
DeVellis's Avatar
It's not real loud but it's noticeable, it almost sounds like something rattling.
Old 01-13-2013, 10:18 PM   #11
Is it only at idle or while driving?
Old 01-13-2013, 10:19 PM   #12
Speed_Mister's Avatar
Region: Arkansas
Yeah I've had that before where my clutch rattled/squeaked at idle but went away when pressing on clutch.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 01-14-2013, 02:27 AM   #13
Region: Nevada
Thats the throw out bearing making the noise.. and u might have stretched the cable
importkiller is offline   Reply With Quote
Old 01-14-2013, 07:05 AM   #14
Mathew r Wright's Avatar
Ok I'm gonna jump in here because I went park my car just a min ago at school and snap!!! I freaked out! Thought ah there goes my clutch! But luckily no I think I just broke my clutch quadrant. After reading these post I am leaning towards the stage II clutch causing this. Any suggestions on getting her home I'm really afraid of getting stuck in traffick?
Mathew r Wright is offline   Reply With Quote
Old 01-14-2013, 09:58 AM   #15
Basically you're gonna have to drive without using your clutch.
Old 01-14-2013, 10:54 AM   #16
1996v6stang's Avatar
How the **** do you do that. I mean i have doen clutchless shifting before but how will u take off/stop without a clutch?
1996v6stang is offline   Reply With Quote
Old 01-14-2013, 11:09 AM   #17
That's kinda what I was wounderin???
Old 01-14-2013, 11:16 AM   #18
When you start to stop you shut off the engine, to start moving you push the clutch in to engage the neutral safety switch and start the engine with the car in gear. The starter should have enough torque to move the car. I had a buddy who's slave cylinder froze up in his Evo. He hated doing it but he managed to get the car home that way.
Old 01-14-2013, 11:49 AM   #19
Couldn't I just buy a quadrant for now to get buy with?
Old 01-14-2013, 12:19 PM   #20
Yeah that should be all you need to fix it. Clutchless driving is only necessary if you NEED to get somewhere and the Mustang is your only transportation.
Old 01-14-2013, 12:20 PM   #21
Well need to get home where tools are handi
Old 01-18-2013, 05:19 PM   #22
DeVellis's Avatar
Throw out bearing is how much to replace? And the cable being stretched makes sense because I can still drive my car what's a new cable cost does anyone know?
Old 01-19-2013, 09:33 AM   #23
Arp products have em as a whole kit for $80 and AM has em for $100...
Old 01-19-2013, 01:03 PM   #24
DeVellis's Avatar
When you say a whole kit what do you mean? The cable and bearing?
Old 01-20-2013, 07:59 AM   #25
Oh no sorry I just mean the cable kit that is adjustable you know. I did not mean bearings an all that sorry no. The whole clutch assembly with new bearings and fork cable an all that is quite a bit more than a hundred dollars lol my fault...
Old 01-30-2013, 08:20 AM   #26
DeVellis's Avatar
Well upon taking my car to ford I ended up replacing...
Clutch, Clutch Fork, Flywheel, and a new Pilot Bearing now when I drive I can't even make it out of first with out spinning the tires.
Old 01-30-2013, 11:11 AM   #27
Lmao that's awesome, mine just broke right after this thread started so I'm dying to get the new clutch cable kit with the quadrant and adjuster. So I can get my baby fixed...
Old 01-30-2013, 08:55 PM   #28
DeVellis's Avatar
I know how you feel I was away from mine only for a week and I was losing it. Lol
Old 01-31-2013, 05:33 AM   #29
Yea +1000 on that...
11:00 AM
