Camber bolts! - Mustang Evolution
Old 01-12-2013, 10:27 AM   #1
Doe_Rae_mi's Avatar
Camber bolts!
I got some eibach camber bolts...I don't know anything about them...am I able to install myself? And where do they even go?
Old 01-12-2013, 10:33 AM   #2
Horseplay's Avatar
please tell me if they work !! i wana buy these for my car. i read the reviews and i read that it helps for a 2" drop.
<subscribed>
Low2v
Old 01-12-2013, 10:50 AM   #3
Doe_Rae_mi's Avatar
<subscribed>
Yep! that's what they do but I don't know a single thing about them lol
Old 01-12-2013, 10:56 AM   #4
1996mustang's Avatar
U should get 2 of them per side so ideally 4 in all. They replace the bolts for the strut and allow for adjustment to the camber for lowered cars
Old 01-12-2013, 11:36 AM   #5
RUNNWLD's Avatar
Region: Utah
They work great I got lowered on the h&r super sports which is one of the lowest springs you can go and they work awesome perfect alignment!!
RUNNWLD is offline   Reply With Quote
Old 01-12-2013, 11:52 AM   #6
Horseplay's Avatar
can u post sum pics of them installed?
Low2v
Old 01-12-2013, 01:46 PM   #7
RUNNWLD's Avatar
Region: Utah
I don't have any pics and I'll have to take my wheel of to take a pic.
Old 01-12-2013, 03:47 PM   #8
Horseplay's Avatar
how many bolts did u buy?
Low2v
Old 01-13-2013, 08:54 AM   #9
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I have Eibach camber bolts along with H&R race springs. I used the camber bolts to add negative camber unlike most people who just want to get back to factory alignment specs because I autocross.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 01-13-2013, 08:56 AM   #10
I used two bolts but four can be used if you need more adjustment. But two in most cases will be fine.
Old 01-13-2013, 08:57 AM   #11
Horseplay's Avatar
nice ! i just wana get my front left tire aligned right . seems to sink in more then my front right tire
Low2v
Old 01-13-2013, 09:07 AM   #12
They were easy to install and adjust, but I didn't have any alignment tools, so I had it aligned professionally with 1.5 degrees of negative camber. Great product, much cheaper than plates if you don't need to adjust caster.
Old 01-13-2013, 09:23 AM   #13
Horseplay's Avatar
where exactly do u install these bolts ?
Low2v
Old 01-13-2013, 11:45 AM   #14
RUNNWLD's Avatar
Region: Utah
Just 1 set on am
Old 01-13-2013, 12:30 PM   #15
I got a moog set from ebay. I installed them myself and got and alighment from a shop. Worked fine.
Cdbformula is offline   Reply With Quote
Old 01-13-2013, 08:52 PM   #16
There are two bolts at the bottom of the front shocks, either one will work.
Old 01-13-2013, 09:04 PM   #17
Tyoung68's Avatar
Where the lower control arms bolt to the frame
Old 01-14-2013, 04:35 PM   #18
The camber bolt replaces one or both of the strut bolts. Its not like chevy lol or like an old school stang where u actually adjust the camber from the control arms
Old 01-14-2013, 07:21 PM   #19
Tyoung68's Avatar
Ha oh oops
Old 01-14-2013, 09:50 PM   #20
no biggie i would love to have your year stang honestly, less of a hassle simple motors simple design, carb mech fuel pump, so simple and yet so awesome to own.
Old 01-14-2013, 10:33 PM   #21
Tyoung68's Avatar
Ha i know! And the engine isnt tucked up under half the dash and even better no power robbing smog!!
04:24 AM
