Squeak - Mustang Evolution
Old 01-12-2013, 01:37 PM   #1
98vertgt's Avatar
Squeak
I have a squeak coming from the drivers side rear of my car. If I'm accelerating or breaking its gone but if I'm just cruising or coasting it just squeaks. Kind of like a chirp. I have a brand new rear end so I don't think it's that. Any ideas?
98vertgt is offline   Reply With Quote
Old 01-12-2013, 02:11 PM   #2
Rm360's Avatar
How long ago did you do the rear end? Couple things off the top off my head could be upper or lower control arm bushings , bad shock, do you have lowering springs? Iso's in or out?
Old 01-12-2013, 02:16 PM   #3
98vertgt's Avatar
Iso's are in, new shocks a couple months ago and I'm lowered. The rear end was done in October.
Old 01-12-2013, 02:35 PM   #4
Rm360's Avatar
Sounds like it could be control arm bushings a good way to tell is to take a look at them if they look dry and cracked they are probably in need of replacement , how's the brakes? A warped rotor or worn pads will also sound like a chirp
Old 01-12-2013, 03:02 PM   #5
Voltage258's Avatar
Region: Utah
Does it sound like this.?? Mine does the exact same thing your describing.
This is the noise mine makes, I have still not figured it out I changed the rear brake pads but that's it. I took it to the Stealership and they said the caliper bolts need to be greased so I had them do it and it did not change anything. Let me know if you figure it out. It has been driving me nuts.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 01-12-2013, 03:07 PM   #6
98vertgt's Avatar
Ill take a look at the brakes and control arm bushings tonight and ill let you know.
---------- Post added at 05:07 PM ---------- Previous post was at 05:06 PM ----------
It sounds exactly like that! It's not that loud yet though but ill definitely let you know what I find out! How long has yours been doing that?
Old 01-12-2013, 03:34 PM   #7
Voltage258's Avatar
Region: Utah
Yeah it is not that loud while driving and it has been doing it for 7-8 months... I screwed with it for like a month and then gave up. I really should have changed the rotors but it's way to cold now. Here is a video of how it sounds while driving you can't really hear it till 46 seconds.
Old 01-12-2013, 03:40 PM   #8
98vertgt's Avatar
That's exactly what it sounds like. I'm gonna check everything tonight, brakes bushings everything.
Old 01-12-2013, 03:48 PM   #9
Voltage258's Avatar
Region: Utah
Yeah let us know. I looked at all mine and sprayed lithium grease on all of them and nothing helped. And the fact that it stops when I press on the brakes makes me belive it has to be something to so with that.
Old 01-12-2013, 11:23 PM   #10
BigB227's Avatar
Same problem with me and I replaced the rear rotor and caliper because the piston in the caliper kept pushing the pad up against the rotor and made a squeak when driving and it went away when the brakes were applied, went to the junkyard and picked up a caliper and boom no more squeak. Just a suggestion at what the problem may be
BigB227 is offline   Reply With Quote
Old 01-13-2013, 09:28 PM   #11
Voltage258's Avatar
Region: Utah
Huh thanks. I will probably try that when it warms up.
Old 01-14-2013, 04:35 PM   #12
98vertgt's Avatar
How did you get the caliper off? My caliper is bad
Old 01-14-2013, 04:45 PM   #13
98vertgt's Avatar
Nevermind I got it
Old 01-14-2013, 10:28 PM   #14
98vertgt's Avatar
The squeak is gone. Take a look at your caliper.. Mine was sticking and wouldn't release pressure on one pad and caused it to make a noise. I know that doesn't make any sense lol but I guarantee it has to do with it.
Old 01-15-2013, 05:01 AM   #15
Voltage258's Avatar
Region: Utah
Alright thanks man. I will give it a look when it warms up outside.
Old 01-15-2013, 04:24 PM   #16
Rm360's Avatar
Glad to see you got it figured out!!!
Old 04-18-2013, 12:30 AM   #17
98vertgt's Avatar
It came back lol
12:41 AM
