02 gt build - Mustang Evolution
Old 01-12-2013, 05:52 PM   #1
Nate98stang's Avatar
02 gt build
So guys over the next year I think I'm going to try and pull my engine get my block redone and get forged internals added, aftermarket heads cams and intake. The pointing the thread will be to share my plans and progress as I get into it. But I also want some help finding the parts as for forged pistons and crank and all that I'm clueless so all suggestions and help is greatly appreciated. I think I wanna go with the stage 2 comp cams from AM and maybe a typhoon intake, but that's all I've become certain of I want.
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 01-12-2013, 08:08 PM   #2
Matticus's Avatar
What's your power goal?
Matticus is offline   Reply With Quote
Old 01-12-2013, 08:54 PM   #3
Mile high JDF's Avatar
*Subscribed*
I would think about going with a forged shortblock, it'll save you some time and hassle for just a bit more money. Also check out the Trick Flow intake manifolds, they are pretty good manifolds (based off the Bullitt design)
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-12-2013, 09:06 PM   #4
Matticus's Avatar
Originally Posted by JDF View Post
*Subscribed*
+1 pretty much anything trick flow is good. They make good heads too. MMR has some good forged rotating assembly kits depending on your power goal and budget.
Old 01-12-2013, 09:11 PM   #5
Horseplay's Avatar
subscribed !
Low2v
Old 01-12-2013, 09:35 PM   #6
Well in the long run I'd like 450ish to the wheels
---------- Post added at 11:33 PM ---------- Previous post was at 11:32 PM ----------
*Subscribed*
The intake ill check out but I think budget wise I could get my block redone with new internals cheaper since I don't want a 700-1000hp car I think my block would b ok
---------- Post added at 11:34 PM ---------- Previous post was at 11:33 PM ----------
As for budget ill be buying things one part at a time slowly doing the build as soon as I get my taxes I'm going to try to get a cherry picker and engine stand then maybe start on the engine pull not long after
---------- Post added at 11:35 PM ---------- Previous post was at 11:34 PM ----------
Originally Posted by Horseplay View Post
subscribed !
Lol u guys will be bored for awhile will def be a slow build
Old 01-12-2013, 09:37 PM   #7
Horseplay's Avatar
lol i dont care as long i stay updated on whats going on lol
Low2v
Old 01-12-2013, 09:39 PM   #8
Sounds good to me lol!
Old 01-12-2013, 09:39 PM   #9
Are you planning on staying all motor? I thoroughly enjoy building everything myself so I know where you are coming from, I figured I would just toss it out. Make sure to get a quality engine stand, not a cheap stand that basically looks like a T. Lots of guys have watched their hard work go up in flames when the wheels have caught a crack and the stand flipped over.
Old 01-12-2013, 09:42 PM   #10
Damn ill def look for a good one then, and after I get the engine back together with new heads and everything I might get a smaller vortech on low lbs just so I can be supercharged lol
Old 01-12-2013, 09:47 PM   #11
That sounds great!
Old 01-12-2013, 09:48 PM   #12
That sounds great!
Yea so I think with like a blower on 6lbs I could get my 450rwhp mark easy if not a little more
Old 01-12-2013, 09:50 PM   #13
Depending on how you build your motor then hell yeah!
Old 01-12-2013, 09:51 PM   #14
Matticus's Avatar
Here ya go.
Old 01-12-2013, 09:51 PM   #15
Matticus's Avatar
Here ya go.
Can't see in pic, but it's $1500 I believe.
Old 01-12-2013, 10:00 PM   #16
Damn I was kinda hoping to buy all the stuff separate to make it easier to buy
Old 01-12-2013, 10:07 PM   #17
Matticus's Avatar
I'm sure you can, that's just a pic I had on hand and from what I've read mmr is pretty reputable. Although kits are generally cheaper overall.
Old 01-12-2013, 10:29 PM   #18
Yea thanks
Old 01-12-2013, 11:47 PM   #19
Might look into this later on http://www.latemodelrestoration.com/...ngine-Kit-44CC
Old 01-13-2013, 01:04 AM   #20
What would some good sites be to get bottom end parts? And what all do I need for a forged bottom end aside from pistons,rings, and a crank?
Old 01-13-2013, 07:08 AM   #21
WheelStander's Avatar
Shraderperformance in NC.
Dang good rep.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 01-13-2013, 08:20 AM   #22
Dang good rep.
They have a website?
Old 01-13-2013, 09:02 AM   #23
Matticus's Avatar
Refer back to that picture on the first page. It's a complete kit as far as I know. And I'm pretty sure you can buy all the pieces separately somewhere.
Old 01-13-2013, 09:56 AM   #24
http://shraderperformance.com/
Old 01-13-2013, 01:05 PM   #25
You're gonna want bearings, piston rings, and definitely some ARP hardware. I've always been a fan of Manley products. They made the rods and pistons for terminators.
Old 01-13-2013, 06:26 PM   #26
Thanks guys ill def be doing a ton of research before I buy any thing I want the build to go as smooth as possible even if it takes awhile
Old 01-13-2013, 09:53 PM   #27
Matticus's Avatar
That's the right mindset, can't wait to see your progress.
Old 01-14-2013, 11:43 AM   #28
Guess I should add on here I want it to be a street/strip build, it will be on the street more than strip but I plan for it to have a lot of track time, I posted at first I want some comp cams but the link I posted I think was the trick flow kit from late model resto , anyone know what the cams r like in the kit, I want a good set of cams that will really rumble
Old 01-14-2013, 12:12 PM   #29
Best bet is to look up the cam specs on Trick Flow's website.
Old 01-15-2013, 12:35 AM   #30
Well that's the thing I don't know what durations are good which are not I'm still new to engines and how everything works I'm probably gonna be paying a guy to strip my block down and add everything bsck and to put my heads and intake on
Old 01-15-2013, 08:21 AM   #31
Matticus's Avatar
Stripping the block isn't bad, just make sure you keep up with all the bolts and lay the heads on their side when you take em off. We stripped an old police interceptor 5.0 in like 40 minutes lol
Old 01-15-2013, 11:14 AM   #32
Well I guess me and dad could take the old heads and intake off I mean the only thing that I'm keeping is the block, aside from alt and pulleys and a/c all that ill keep
Old 01-15-2013, 11:30 PM   #33
Since I'm going to end up with a centri blower, what extra maintenance needs to be done on a supercharged car to make sure everything stays in check and nothing blows , or what needs to be maintained so that all the seals in the blower are fine and everything
Old 01-16-2013, 06:33 AM   #34
Matticus's Avatar
Intercooler/after cooler depending on what blower you go with, and most importantly is a good dyno tune.
Old 01-16-2013, 10:33 AM   #35
Don't have to do anything ever few miles or anything?
06:42 PM
