What TB/Plenum Combo U Run ? - Mustang Evolution
Old 01-13-2013, 08:06 AM   #1
Horseplay's Avatar
just curious to see what combo's you guys are running
Low2v
Old 01-13-2013, 08:08 AM   #2
jdavis96gt's Avatar
Region: West Virgina
Stock lol. Next month plan on purchasing trick flow plenum and prob SR TB.
Old 01-13-2013, 08:15 AM   #3
1lowGT's Avatar
+1 me too
Old 01-13-2013, 08:19 AM   #4
1996mustang's Avatar
75 mm c&l tb and plenum
Old 01-13-2013, 08:21 AM   #5
Horseplay's Avatar
where did u buy the c&l tb ? i saw the plenum on cnlperformance but i didnt see the tb
Low2v
Old 01-13-2013, 08:24 AM   #6
BigB227's Avatar
I'm running the trickflow throttle body and plenum
BigB227 is offline   Reply With Quote
Old 01-13-2013, 08:28 AM   #7
Idk either lol its been a long time however if i could id get the accufab tb/plenum setup prerty worth while
Old 01-13-2013, 08:29 AM   #8
Horseplay's Avatar
was it an easy install with those? ive been leaning towards the trick flow combo on summitracing . and how does ur car run with that combo ?
Low2v
Old 01-13-2013, 08:56 AM   #9
cliffyk's Avatar
Professional Products 70 mm TB and upper plenum (Pro Products and TrickFlow TBs and plenums are the same):
The stock plenum is the weak link, a 70 mm TB and any aftermarket plenum is all the 4.6L 2V requires to get all the air it needs--read more about that here...
Old 01-13-2013, 09:26 AM   #10
Horseplay's Avatar
where did u buy them ?
Low2v
Old 01-13-2013, 11:56 AM   #11
cliffyk's Avatar
eBay...
Old 01-18-2013, 10:41 PM   #12
Uhh taken's Avatar
Accufab 70mm combo
Uhh taken is offline   Reply With Quote
Old 01-18-2013, 11:18 PM   #13
BigB227's Avatar
Trickflow 70mm throttle body and upper plenum
Old 01-18-2013, 11:19 PM   #14
BigB227's Avatar
My car runs real good with it, I'm very pleased with the combo. The install was very straightforward and easy, no real snags I can complain about
Old 01-19-2013, 12:31 AM   #15
JetLife 01GT's Avatar
Lmr sells professional products
http://www.latemodelrestoration.com/...s-Satin-Intake
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-19-2013, 06:40 AM   #16
AgentOrange's Avatar
I'm using the BBK 78mm throttle intake.
AgentOrange is offline   Reply With Quote
Old 01-19-2013, 12:11 PM   #17
2002VertGT's Avatar
Same here..may be more than it needs but configural is in my future and I will benefit from it then.
4.10 Gear/RPM thread
Old 01-19-2013, 01:27 PM   #18
sLbxO143's Avatar
+1
sLbxO143 is offline   Reply With Quote
Old 01-19-2013, 02:28 PM   #19
jjsg09's Avatar
I run Accufab 75mm throttle and plenum.
Old 01-19-2013, 07:55 PM   #20
Jredherr's Avatar
I am running accufab plenum and ford racing 75mm.
Jredherr is offline   Reply With Quote
04:18 PM
