02 GT oil capacity - Mustang Evolution
Old 01-13-2013, 10:54 AM   #1
v8pony's Avatar
02 GT oil capacity
So in the Internet it is impossible to get a direct answer..many people say 5 qts, many say 6..I read 99-01 take 5 qts and 02-04 take 6, Than I read 99-01 takes 6 and 02-04 take 5, very confused..just changed my oil with filter..added 5 1/2 quarts and it appears the dipstick is showing over filled but we all know how these dipsticks S*CK!! How much oil goes in here..btw if it matters my car was built 01/02
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-13-2013, 11:00 AM   #2
fomoco4life's Avatar
My 04 holds 5, u dont have ur owners manual?? (Its n there)
Old 01-13-2013, 11:41 AM   #3
v8pony's Avatar
No owners manual
2002 5spd GT
Old 01-13-2013, 11:42 AM   #4
1lowGT's Avatar
Mines 6 or that's how much I put in it lol
Old 01-13-2013, 11:46 AM   #5
v8pony's Avatar
Now I'm thinking I should drain some..put in 5 1/2 and seems its over the max line
2002 5spd GT
Old 01-13-2013, 12:15 PM   #6
cliffyk's Avatar
You can download an owner's manual here. The recommended capacity for 2002 is 6.0 quarts.
However all 4.6L Mustangs should run 6.0 qt of motor oil. The original spec was 5 qt but it was found in late 2000 during some independent testing that there was a possibility of oil starvation in high-G turns, with the 5 quart fill. It is a slim possibility for a DD street car but a possibility nonetheless, so Ford raised the recommended fill to 6.0 qt in 2002.
The only other change was to the markings on the dipstick--same oil pan just more oil in it.
Here is a Ford TSB re: dipstick markings.
Old 01-13-2013, 12:27 PM   #7
I put 5.5 in our 04gt.
Old 01-13-2013, 01:06 PM   #8
cliffyk's Avatar
Just curious, why? That's 1/2 qt low...
Old 01-13-2013, 01:14 PM   #9
MineralGrayGT's Avatar
Region: Wyoming
Ive gotten 6 in my 02
MineralGrayGT is offline   Reply With Quote
Old 01-13-2013, 01:24 PM   #10
v8pony's Avatar
My dipstick def looks like it reads over the max..as of right now I put in 5.5 qts of oil..so I can safely put in the other .5 ? Reason I ask is because this dipstick sucks and realllllly don't trust it..drained my oil for 10-15 minute and also changed the filter so pretty sure it was pretty damn empty except for maybe a bit left over from the car being up on blocks for an exta 8' to work under the car . the car was at normal temp when i drained the oil as well...
2002 5spd GT
Old 01-13-2013, 01:57 PM   #11
Mzilla's Avatar
You should run 6 Quarts in your 4.6 period.
Mzilla is offline   Reply With Quote
Old 01-13-2013, 03:31 PM   #12
v8pony's Avatar
Now I'm screwed..broke my dipstick thing is a POS!!! Can't find one anywhere but LMR and its 25$ and out of stock..any suggestion? Now I'm just 5.5 qts of oil in and def ain't getting a reading with the dip stick..should I just dump the other .5 qt in there to be safe of what? Anyone know where to buy a dipstick from for a 02 mustang 4.6
2002 5spd GT
Old 01-13-2013, 03:48 PM   #13
sally2002's Avatar
I run 6 qts in mine
sally2002 is offline   Reply With Quote
Old 01-13-2013, 03:55 PM   #14
1lowGT's Avatar
Junk yard??
Old 01-13-2013, 04:07 PM   #15
v8pony's Avatar
Originally Posted by 1lowGT View Post
Junk yard??
Yea ill try it tomorrow..gonna have to be for a 02-04 GT, from what I read online they changed the dipsticks..found one on cjponyparts for a whopping 35$ damnnnn
2002 5spd GT
Old 01-13-2013, 04:08 PM   #16
1lowGT's Avatar
I see. Well good luck. You got any junk yards around you?
Old 01-13-2013, 04:14 PM   #17
v8pony's Avatar
Yep got one 2 blocks from where I work..ill call em in the morning, if not looks like ill be paying 35$ to cjponyparts for a new one
2002 5spd GT
Old 01-13-2013, 04:18 PM   #18
Because that shows full.
I'll bet many people don't fill the oil filter before installation. I also prime the system before checking level.
I run 6.5 in the cobra using the same procedure.
Old 01-13-2013, 07:36 PM   #19
1996v6stang's Avatar
Should it be checked running or off? Ive never really known this.
1996v6stang is offline   Reply With Quote
Old 01-13-2013, 07:49 PM   #20
1lowGT's Avatar
Off on a flat surface
05:01 PM
