Best gas? - Mustang Evolution
Old 01-13-2013, 11:58 AM   #1
02StangGT's Avatar
Best gas?
I was wondering what do you guys thing the best gas you guys run in your stangs
02StangGT is offline   Reply With Quote
Old 01-13-2013, 12:09 PM   #2
Venomouz831's Avatar
91 chevron or shell
)02 Gt, Founder of WE2G
Old 01-13-2013, 12:13 PM   #3
deadsp0t's Avatar
A BP station near me has 100 octane, I always run BP or Exxon 93.. There is also a station around here packing 114 too..
That's unimpressive
Old 01-13-2013, 12:32 PM   #4
1996v6stang's Avatar
You obviously aint in cali haha all we have is 87 89 or 91. Haha
1996v6stang is offline   Reply With Quote
Old 01-13-2013, 12:41 PM   #5
NoStangNewb's Avatar
Octane doesn't matter unless you have a higher compression engine. Use what is recommended in your owner's manual. If you use Nitrous, or boost of some sort, then it's a good idea to use a higher Octane rating to prevent detonation. There is no power benefit between the different grades. As for which brand, they're all the same. They all come from the same refineries and tank farms. Typically most areas are serviced from anywhere between 2 to 4 different fuel farms, all of which get their fuel piped from the same refineries. The only difference may be a couple different additives, despite what the commercials claim. Typically, if someone says, "don't go to that gas station, they have bad gas, I had this expericence.." it's because that particular gas station's tanks are probably contaminated or have water in them or whatever. The fuel delivered to the gas stations has been filtered quite a bit so typically it goes into the tanks under normal conditions. Hope this helps!
NoStangNewb is offline   Reply With Quote
Old 01-13-2013, 01:16 PM   #6
MineralGrayGT's Avatar
Region: Wyoming
In Wyoming we have 87 91 93 and thats it so i run 91 and i seem to like it alot.
MineralGrayGT is offline   Reply With Quote
Old 01-13-2013, 01:38 PM   #7
98StangKid's Avatar
I run nothing but 93 in mine.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 01-13-2013, 01:43 PM   #8
I'm in Cali and a place near my dads work sells something over 100. I forgot the exact number though. But it's not a regular gas station.
Old 01-13-2013, 01:48 PM   #9
ShelbyGT500B's Avatar
I use 93
ShelbyGT500B is offline   Reply With Quote
Old 01-13-2013, 02:20 PM   #10
deadsp0t's Avatar
Probably 110..
The 100 here is labeled as sprint racing fuel and the place that carries 114 also has 110.. My bike LOVES 100...
That's unimpressive
Old 01-13-2013, 03:37 PM   #11
02StangGT's Avatar
Now is it true the higher the number the faster it.Burns
Old 01-13-2013, 03:57 PM   #12
taylor98gt's Avatar
Probably 110..
+1 I ran 114 in my dirtbike and with octane booster. It loved it lol, wasn't stock though either
taylor98gt is offline   Reply With Quote
Old 01-14-2013, 02:08 PM   #13
Automotive grade fuel will burn faster only dependent upon the amount of ethanol in the fuel. Most standard fuel regardless of octane rating has a 10% ethanal rating. However, E85 has an 85% ethanol rating and will burn faster than standard fuel grades, but will also provide higher power from the fuel or better fuel mileage depending on the weight of your foot. Hope this helps.
11:15 PM
