P0174 - Mustang Evolution
Old 01-14-2013, 03:23 PM   #1
98GTCONV's Avatar
P0174
Got this code, looked it up, recommends that I clean the MAF sensor. How do I go about doing that? Take off cai, unplug it and spray it inside where the plug goes?
98GTCONV is offline   Reply With Quote
Old 01-14-2013, 03:24 PM   #2
v8pony's Avatar
Unplug maf, unscrew it, buy a can of CRC MAF cleaner, spray it inside on the wires..let sit for a few moments and plug and screw back in
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-14-2013, 03:27 PM   #3
98GTCONV's Avatar
Spray the MAF itself inside and inside the plug?
Old 01-15-2013, 12:18 PM   #4
98GTCONV's Avatar
I cleaned MAF and reinstalled it. T
Removed the code and drove it for 30 minutes. Check engine light popped up again same code. What else could it be?
Old 01-15-2013, 01:16 PM   #5
9tee7pony's Avatar
There could be air getting in between the maf and tb. When I got that code the coupler behind the maf was letting air in. It could also be a vacuum leak.
9tee7pony is offline   Reply With Quote
Old 01-15-2013, 01:48 PM   #6
BigB227's Avatar
Im not trying to hijac the thread but I am having the same exact problem with my gt so I'm interested in hearing the solution, I had one source tell me that a faulty PCV valve could cause this code but I havnt replaced it yet
BigB227 is offline   Reply With Quote
Old 01-15-2013, 03:48 PM   #7
Mustang_Madness's Avatar
Can't have a vacuum leak. Not possible Haha but def. air could be getting out lol. Just tighten down all clamps, secure everything, clean the TPS and troubleshoot. Might be a O2 sensor as well! It running kinda bad or what?
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 01-15-2013, 03:49 PM   #8
1996mustang's Avatar
faulty pcv valve, vacuum leaks bad maf, bad o2s since p0174 is bank 2 lean, many causes.
Old 01-15-2013, 09:18 PM   #9
98GTCONV's Avatar
I think my O2 sensors are bad. Mine randomly lost power and throttle response today. Had to smash the gas for it to accelerate.
Old 01-16-2013, 03:52 PM   #10
9tee7pony's Avatar
I ended up frying an O2 sensor because I waited to long to fix it. Now I get code p1131.
Old 01-16-2013, 04:06 PM   #11
austinknoll's Avatar
Just replace your pcv valve. It can't hurt especially if its stock. Easy as hell as well
---------- Post added at 05:06 PM ---------- Previous post was at 05:05 PM ----------
If its having trouble accelerating, it might be the maf sensor. My friend put mine on and didn't plug it in so I drove to school and the thing too forever to accelerate. Then I found out his dumbass didn't even fully plug it in haha.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 01-16-2013, 05:46 PM   #12
98GTCONV's Avatar
It just did it once when it didn't accelerate. I clean my MAF. Didn't look dirty in the first place...
09:29 AM
