Check Engine Ligh - Mustang Evolution
Old 01-17-2013, 01:01 PM   #1
ccabral14's Avatar
Check Engine Ligh
Today my check engine light came on in my 02 mustang gt, its been running perfectly, oil pressure is fine, so I have no idea what's causing it. I recently installed a bassani catted x pipe; would that make it come on? I'm still going to have it checked with a mechanic anyway, just wanted some input.
ccabral14 is offline   Reply With Quote
Old 01-17-2013, 01:39 PM   #2
Mfore33's Avatar
If it runs fine check the gas cap. I had the gasket tear and the light would come on
Old 01-17-2013, 08:23 PM   #3
1996mustang's Avatar
My guess is to go to autozone and get the codes read. Then post the codes here and we could tell u what they are and possible causes and yes maybe ur exhaust mod affected the o2 or set off an o2 code nothing to worry about when u reset the ecu. Atleast thats what i would do is reset the ecu to relearn with the bew exhaust
Old 01-17-2013, 08:31 PM   #4
Venomouz831's Avatar
If you just installed a off road mid then most likely something to do with you're 02
)02 Gt, Founder of WE2G
check engine
01:33 AM
