Cam on 01 GT - Mustang Evolution
Old 01-17-2013, 05:33 PM   #1
02YellowGT's Avatar
Cam on 01 GT
Is it worth the time and money to put a cam in my stock 02 GT??
02YellowGT is offline   Reply With Quote
Old 01-17-2013, 05:36 PM   #2
Mzilla's Avatar
What else do you have done to your car?
Mzilla is offline   Reply With Quote
Old 01-17-2013, 05:42 PM   #3
Defying_Fate's Avatar
I have a 01 GT. the cams was probably the best i investment I bought other then the tuner. Definitely worth it.
Defying_Fate is offline   Reply With Quote
Old 01-17-2013, 05:49 PM   #4
02YellowGT's Avatar
Engine is stock I only have an exhaust
Old 01-17-2013, 07:30 PM   #5
jjsg09's Avatar
I've been researching, actually right now I'm in the middle of it. For the last few months I've been researching cams and long story short I have found that Hitech cams seem to be the best. They have been proven to add the most hp to stock heads and fully bolt on cars. Stage 2 Hitech cams have been dyno proven to put you up to 300 hp. Now that's pretty highly bolt on cars. Also you don't have to change out the stock valve springs with the stage 2. I'm looking into getting these in my car.
---------- Post added at 09:30 PM ---------- Previous post was at 09:28 PM ----------
Here's a video
http://youtu.be/I2pzrQlwp9g
Old 01-17-2013, 07:30 PM   #6
02YellowGT's Avatar
Thanks for the info. Would I need to add gears? Would it help?
Old 01-17-2013, 07:34 PM   #7
jjsg09's Avatar
Most cams yes you do I think stage 1 you don't have to. But stage 1 cams might not be worth the hassle.
Old 01-17-2013, 07:38 PM   #8
02YellowGT's Avatar
Thanks for the link and info. It really helps.
Old 01-18-2013, 06:45 AM   #9
lee1rbc's Avatar
You can find 25 more peak h.p. with cams but you will loose about the same in low end power 2500 to 3500 rpms, so gears are a must. The real issue for making power with a 2v is the heads. I still think cams are worth it if you do the work.
2001 SVT Cobra 04 Mach 1 motor & trans, 01 Cobra cams, bassani x, flowmaster catbck, JLT CAI, 4.11 gears, Tokico D-specs, eibach springs.
lee1rbc is offline   Reply With Quote
Old 01-18-2013, 07:05 AM   #10
jjsg09's Avatar
Yea right now im trying to find a good safe way to do mine myself. If I can get that tool that holds the cam gear in placd and just do a swap it sounds to me what im reading I should be golden. Hitech says doesn't really need degreed for the stage 2 but after that it does. I am reading comp cams stage 2 its a must to degree them or you will get ptv.
Old 01-21-2013, 02:28 PM   #11
lee1rbc's Avatar
It's not hard to swap cams. The tool you are talking about is really used to take the tension off the chain so you can remove and re-install the cam gear without removing the timing cover. I like the results for both stage 1 and stage 2 hi-tech cams.
Old 01-21-2013, 02:58 PM   #12
jjsg09's Avatar
If you're going to do the work which would you prefer on a street car
Old 01-21-2013, 03:42 PM   #13
lee1rbc's Avatar
I personally would do stage 1 hi-tech especially if it's a daily driver, get 4.10 tb ,plenum and a good tune Maybe be at 285-290rwhp and still have low end power.
Old 01-21-2013, 04:08 PM   #14
lee1rbc's Avatar
But honestly, there are so many good results with the Hi-tech stage 2 cams. If you like to go to the track get stage 2, if you never go to the track stage 1.
Old 01-21-2013, 05:20 PM   #15
jjsg09's Avatar
I have read that hitech stage 2 is really nice. I think i will go with those or MHS cams, heard good things from theres too. Do you know if they need new cam bolts or can the stock ones be reused?
Old 01-21-2013, 07:39 PM   #16
lee1rbc's Avatar
Are you talking cam gear bolts? I guess it never hurts to replace but I have never heard of a need to do it. I would talk with MHS or Hi-tech before buying to make sure nothing else is needed.
Old 01-21-2013, 07:43 PM   #17
jjsg09's Avatar
Sorry yes cam gear bolts. I ask because comp cams you have to use a different bolt and didnt know if that applied to all new cams.
06:15 PM
