Question to anyone? - Mustang Evolution
Old 01-19-2013, 09:01 PM   #1
TheDarkKnight's Avatar
Question to anyone?
I have recently bought a 2000 GT! The car is great but there is one problem. There is a loud grinding, whinnying, annoying sound coming from the rear end... I think it might be the differential but can anybody tell me what it is for sure? Thanks guys
TheDarkKnight is offline   Reply With Quote
Old 01-19-2013, 10:18 PM   #2
1996mustang's Avatar
Id bet it may be the diff making the noise. One way to check is lift the rear on jack stands and spin the wheels to listen to grinding.
Old 01-19-2013, 11:30 PM   #3
1slosix's Avatar
i'd flush the old fluid out and check with a magnet for metal shavings..most likely the teeth are ground down.
carving corners like a boss
Old 01-20-2013, 12:36 PM   #4
cliffyk's Avatar
You don't have to check with a magnet--to get the fluid out you need to pull the differential housing cover so just take a look and see what you can see...
Old 01-20-2013, 07:30 PM   #5
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
I thought it was my differential too until I lifted up and check it was my Differential damper Which I just removed
96NYCGT is offline   Reply With Quote
Old 01-20-2013, 07:43 PM   #6
cliffyk's Avatar
It is very unlikely that the differential damper ("dogbone") would cause the noises the OP describes--very unlikely...
Old 01-20-2013, 08:07 PM   #7
+1 the nvh wouldnt make a grinding whining sound since its only a damper. the op describes possible differential with no oil in it, or worst case scenario, like obama said its time for a change, differentials that is.
Old 01-20-2013, 10:16 PM   #8
Mfore33's Avatar
Mine did this and it was the carrier bearing going out.
Old 01-21-2013, 01:57 PM   #9
Thanks for the tips everyone! I'm gonna get to the bottom of if soon... I really appreciate the help
06:59 AM
