H pipe - Mustang Evolution
Old 01-20-2013, 12:58 PM   #1
RUNNWLD's Avatar
Region: Utah
H pipe
Okay do I have money to buy the off-road h pipe but I have emissions here in Utah and I would just switch to my factory pipe when I have emissions, but I am just afraid by switching back and forth I will screw things up and not be able to pass emissions what you guys think?
RUNNWLD is offline   Reply With Quote
Old 01-20-2013, 01:13 PM   #2
Venomouz831's Avatar
No you won't screw anything up unless you mess up one of you're o2, I switch back and forth all the time easy 10 min
)02 Gt, Founder of WE2G
Old 01-20-2013, 01:13 PM   #3
RUNNWLD's Avatar
Region: Utah
How would I screw up my 02 sensors?
Old 01-20-2013, 01:21 PM   #4
jjsg09's Avatar
I wouldn't be as worried about your o2 sensors but worry that you will strip a exhaust manifold stud. You should be fine doing what your saying but be careful.
Old 01-20-2013, 01:26 PM   #5
RUNNWLD's Avatar
Region: Utah
Okay I think I might do it!! I hope I will see a sound difference.
---------- Post added at 01:26 PM ---------- Previous post was at 01:23 PM ----------
Do I need to buy new 02 sensors or just extensions?
Old 01-20-2013, 01:31 PM   #6
jjsg09's Avatar
If you'r 02 year and up you need extensions and you will not need to buy new o2 sensors. O2 sensors are tuff to get out unless you have a o2 socket made for it and also spray a little pb blaster on it to knock off rust. I have the MAC h-pipe on mine and YES very noticeble difference. I like h over x pipes
Old 01-20-2013, 01:42 PM   #7
RUNNWLD's Avatar
Region: Utah
Okay sweet! Where do you get on plaster?
Old 01-20-2013, 01:43 PM   #8
I stepped and cracked my last 02 lol so I had to buy a new one
Old 01-20-2013, 01:45 PM   #9
RUNNWLD's Avatar
Region: Utah
Okay I'm going to purchase the pypes o/r h and sr o2 extensions.
Old 01-20-2013, 01:50 PM   #10
RUNNWLD's Avatar
Region: Utah
Is that all I need?
Old 01-20-2013, 02:46 PM   #11
jjsg09's Avatar
Originally Posted by RUNNWLD View Post
Is that all I need?
Yes. Have you ever taken off a stock mid pipe? The passenger side is a b!$& to get off. The top bolt is the hardest and it can easily be rounded off. I used extensions that wobble and it worked like a charm. Pb blaster is your best friend during this job.
Old 01-20-2013, 04:20 PM   #12
RUNNWLD's Avatar
Region: Utah
Okay so my dad talked me out of getting the pipe and buying something else for the car sense my emmisions are in may ill just buy one after that so it will be summer then and be warm to put it on. So now I got to decide what to get?
Old 01-20-2013, 07:18 PM   #13
JetLife 01GT's Avatar
Tb/plenum
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-20-2013, 07:27 PM   #14
RUNNWLD's Avatar
Region: Utah
Is the thornless body and plenum really noticeable?
Old 01-20-2013, 07:33 PM   #15
jjsg09's Avatar
YES and throw in Steeda under drive pulleys
Old 01-20-2013, 07:36 PM   #16
Yup. Much better throttle response
2001 GT
Old 01-20-2013, 08:23 PM   #17
RUNNWLD's Avatar
Region: Utah
I have under drive pullies I just need to put them on but I think I might just get some more interior things and save some cause I'm going to be going on a cruise soon so.
Old 01-20-2013, 08:27 PM   #18
jjsg09's Avatar
Hey the Mods never end sooner or later you will come back around to it. Happy hunting! What interior mods are you thinking?
Old 01-20-2013, 09:16 PM   #19
RUNNWLD's Avatar
Region: Utah
The gauge ring bezels and mgw ebrake handle and redoing my interior in carbonfiber. But I am now thinking wheel spacers sense I have the stock 17x8 bullits still to give me a wider stance since I'm lowered it will look good?
Old 01-20-2013, 09:20 PM   #20
BigB227's Avatar
My stang is an 03 and I have the MAC prochamber, I didn't need to buy O2 extensions
BigB227 is offline   Reply With Quote
Old 01-20-2013, 09:25 PM   #21
Sonicblue11's Avatar
Make sure you don't break a manifold bolt! Heat them up until cherry red then the nuts will come right off, I had to do this because my h pipe was never taken off since factory
Sonicblue11 is offline   Reply With Quote
02:29 PM
