Rear axle - Mustang Evolution
Old 01-21-2013, 01:11 PM   #1
02StangGT's Avatar
Does anyone know how to remove the rear axle?
02StangGT is offline   Reply With Quote
Old 01-21-2013, 04:44 PM   #2
Voltage258's Avatar
Region: Utah
As in the entire axle? Or just the axle shafts?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 01-24-2013, 08:08 AM   #3
02StangGT's Avatar
Just the shafts
Old 01-24-2013, 08:26 AM   #4
Just the shafts
Drain diff fluid. Pull diff cover. Rotate diff till you can see the c clips. Use magnet or long pliers to remove. Pull axles out.
Old 01-24-2013, 08:41 AM   #5
Forgot to mention, remove brake calipers and rotors.
Old 01-24-2013, 09:09 AM   #6
02StangGT's Avatar
Cool thanks for the help!
Old 01-24-2013, 09:39 AM   #7
Tyoung68's Avatar
Youtube it
Old 01-24-2013, 10:17 AM   #8
cliffyk's Avatar
You have to remove the pinion shaft too, or the axles will not push in and allow the C-clips to be removed.
BUT!!!
Before pushing the axles in remove the ABS sensors from the backing plates--if this is not done they can be damaged.
Here is the axle removal procedure from the shop manual...
05:01 AM
