Suspension ideas - Mustang Evolution
Old 01-22-2013, 09:48 AM   #1
Banks's Avatar
Suspension ideas
I have an 02 mustang gt and my suspension is holding me back. Need ideas on what I should get and what's not worth the money. Coil over kit? I do need a drop in ride hight though. And a stiffer ride.
Banks is offline   Reply With Quote
Old 01-22-2013, 09:56 AM   #2
What are your goals? Drag/autox/road course?
Old 01-22-2013, 10:13 AM   #3
Banks's Avatar
Drag. But still be able to drive it as a weekend driver
Old 01-22-2013, 10:49 AM   #4
In that case lower and stiffer is not what you want...
Old 01-22-2013, 10:57 AM   #5
Banks's Avatar
What would u suggest?
Old 01-22-2013, 11:02 AM   #6
For a good drag transfer you want the suspension to transfer weight to the rear for traction.
The best way to do this and keep it streetable is adjustable shocks and struts and a quality set of control arms.
Springs can go either way and I know you want to go lower but just remember that shortens the amount of travel you can use to transfer weight.
I like the lowered look and my car tucks the tires when launching because I wanted it lowered. Just not the optimum setup
Old 01-22-2013, 11:05 AM   #7
Venomouz831's Avatar
Also look into tires as that will help you,
)02 Gt, Founder of WE2G
Old 01-22-2013, 11:10 AM   #8
Banks's Avatar
Do u have a preferred brand? Not to worried about the money.
Old 01-22-2013, 11:20 AM   #9
For suspension or tires?
Old 01-22-2013, 11:22 AM   #10
Banks's Avatar
Suspension. Tires I ordered the nitto staggered 03 cobra wheels
Old 01-22-2013, 11:24 AM   #11
Good that will help you alot. To tell you the truth I had my previous stang set up for auto x and used the same stuff for drag racing and got me good times. You can do gears as well
Old 01-22-2013, 11:25 AM   #12
Banks's Avatar
What set up did you have?
Old 01-22-2013, 11:27 AM   #13
I had coilovers all around, rear control arms, sway bars, gears, k member, cc plates, exhaust, intake, tb, 305 Hoosier dr's and some weight reduction like no rear seats and lightweight sparco racing seats and light cowl hood
Old 01-22-2013, 11:30 AM   #14
Banks's Avatar
What brand coil overs do u have?
Old 01-22-2013, 11:32 AM   #15
If I remember I had Griggs racing up front and koni in the back
Old 01-22-2013, 11:35 AM   #16
1slosix's Avatar
cut your springs....it is a great drag spring thanks to how well the stockers transfer weight....just cut a coil all the way around you'll have a car that sits nice, but better yet launches nice. also look into drag bags for the rear
carving corners like a boss
Old 01-22-2013, 11:36 AM   #17
Banks's Avatar
Ok. Do you know anything about Lakewood for shocks and struts? Are they reliable.
Old 01-22-2013, 11:39 AM   #18
1slosix's Avatar
yes they do the job nicely
Old 01-22-2013, 11:40 AM   #19
1slosix's Avatar
here's some cut springs on one of the fastest n/a 2v GTs i know...
Old 01-22-2013, 11:41 AM   #20
They are a good brand
Old 01-22-2013, 11:48 AM   #21
Banks's Avatar
Ok good to know. Thanks for all the input
Old 01-22-2013, 11:48 AM   #22
No problem
Old 01-22-2013, 11:49 AM   #23
1slosix's Avatar
it's why this forum is so busy...we're all just here to help
Old 01-22-2013, 12:50 PM   #24
Personally i'm running strange adjustables, v6 springs, metco adj upper control arms, j&m weight jacker lower control arms, a bunch of bracing and a built rear. It's enough for a 1.6 60 on drag radials, shooting for low 1.5 on slicks. Not bad for a 3900# convertible
Old 01-22-2013, 12:58 PM   #25
Banks's Avatar
That's not bad at all
Old 01-22-2013, 01:00 PM   #26
Just showing you can piece it together with quality used parts and still have a good setup. I autox on the same setup as well
Old 01-22-2013, 01:10 PM   #27
Banks's Avatar
U don't have any problems with the car having a lot of roll on that set up?
Old 01-22-2013, 01:20 PM   #28
Nope, I stiffen the shocks and struts up a few notches when not at the strip.
Old 01-22-2013, 01:23 PM   #29
Banks's Avatar
Alright. Sounds good. Thanks for all the help y'all
10:29 PM
