fog light switch - Mustang Evolution
Old 01-22-2013, 01:35 PM   #1
Horseplay's Avatar
fog light switch
if the little light doesnt turn on, does that mean the fog light switch doesnt work? when i got the car it was missing the fog lights. i have the switch in the car and i can see the harness . i ordered some fogs yesterday and i tried turning on the button but it doesnt light up. is that because i dont have any fogs connected yet? or because i need a new switch? could use some help
Low2v
Old 01-22-2013, 01:39 PM   #2
1slosix's Avatar
my v6 had the oem switch from factory but no fogs of course...the switch will light up reguardless of being hooked to fogs...so either the switch is shot or it's not getting power
carving corners like a boss
Old 01-22-2013, 01:42 PM   #3
Banks's Avatar
My GT doesn't have lights but my switch still lights up
Banks is offline   Reply With Quote
Old 01-22-2013, 01:50 PM   #4
Rm360's Avatar
The light should turn on if the fogs are working , check the fuse , if fuse is good, there is a relay in the fuse block in the engine compartment for the fogs, change that relay and that should fix the problem
Old 01-22-2013, 02:07 PM   #5
Horseplay's Avatar
awesome idea! do u know which is the one for the fogs by any chance?
---------- Post added at 03:07 PM ---------- Previous post was at 03:06 PM ----------
yeah i hope its just the fuse. rght now i'll check as soon as i figure out which one is for the fogs lol
Low2v
Old 01-22-2013, 02:26 PM   #6
Rm360's Avatar
The fuse is F2.38 it's the 3rd fuse from the left on the bottom row it's a 20 amp fuse
Old 01-22-2013, 03:39 PM   #7
Mfore33's Avatar
I've got a gt and my fogs work but the light is burned out on the switch
Old 01-22-2013, 03:41 PM   #8
Horseplay's Avatar
and ur lights still work?
Low2v
Old 01-22-2013, 03:52 PM   #9
Mfore33's Avatar
yes
Old 01-22-2013, 04:16 PM   #10
cliffyk's Avatar
The parking lights, or headlights on low beam, have to be on for the fog lamps to turn on. unless the wiring is altered---here's how to make the fog lights turn on independently, and still turn off with the key...
Old 01-23-2013, 07:45 AM   #11
v8pony's Avatar
Originally Posted by cliffyk View Post
The parking lights, or headlights on low beam, have to be on for the fog lamps to turn on. unless the wiring is altered---here's how to make the fog lights turn on independently, and still turn of with the key off...
+1 that's what i did, so much better!
2002 5spd GT
Feb 2013 Mustang of the Month
06:19 PM
