Cheap coilivers? - Mustang Evolution
Old 01-23-2013, 05:57 AM   #1
Uhh taken's Avatar
Cheap coilivers?
I'm thinking about getting a pair but I don't want them to an outrageous price. I'm either gonna get some or cut the stock springs which would be better as a dd? Primarily but drag every so often? Got any suggestions?
-Henry
Uhh taken is offline   Reply With Quote
Old 01-23-2013, 06:50 AM   #2
Suspension is one area buying the cheapest available parts is not the best move. You depend on that to keep your car going down the road
Old 01-23-2013, 09:02 AM   #3
Uhh taken's Avatar
True but don't have funds for expensive coil overs right now so should I just cut the springs for now or what?
Old 01-23-2013, 09:18 AM   #4
cliffyk's Avatar
^+1, "cheap" and "suspension" do not belong in the same sentence...
Old 01-23-2013, 10:12 AM   #5
Ewokjax95's Avatar
Cheap Coilovers for a mustang lol
Ewokjax95 is offline   Reply With Quote
Old 01-23-2013, 10:29 AM   #6
1slosix's Avatar
cutting is a great option OP...although i will say if you can afford lowering springs for a DD you'll enjoy them more. However if you plan to drag alot cutting would put a smile on your face. I've cut a lot of stangs and i've found the best drop is cutting 1.25 coils off the front and 1 coil off the back with no isolators..the ride isn't bad, and it transfers weight nicely to the rear when you launch..always made my GT do nicely when at Beech Bend. If actual lowering springs are in the budget but you aren't wanting to spend a load check out SR Performance on AM. Hard to beat the quality for the money. PM me if you have any questions on cutting
carving corners like a boss
Old 01-23-2013, 10:29 AM   #7
98vertgt's Avatar
-Henry
Get springs for now
98vertgt is offline   Reply With Quote
Old 01-23-2013, 11:13 AM   #8
Uhh taken's Avatar
If I get just springs won't it make the ride bouncy? Or should I get struts as well and if so what are some good brands? Thanks.
-Henry
Old 01-23-2013, 11:19 AM   #9
Uhh taken's Avatar
If I only got lowering springs wouldn't it make the ride bouncy? Also any good name brands to look into? Thanks.
-Henry
Old 01-23-2013, 07:14 PM   #10
Springs will make the ride more stiff. It will be more fun to drive in the curves and looks badass.
Cdbformula is offline   Reply With Quote
Old 01-24-2013, 03:26 AM   #11
Uhh taken's Avatar
Well if all I need is springs I'll just do that but I thought I would need struts etc.
Old 01-24-2013, 01:37 PM   #12
98vertgt's Avatar
It depends on how low you go. If you're lower than an inch or inch and a half get struts too. I have h&r super sports with tokico blues and my cars drives and rides like a dream. Check out eibach too
03:01 AM
