2004 cobra line locks - Mustang Evolution
Old 01-23-2013, 08:05 AM   #1
frank07stanggt's Avatar
Ok I've installed line locks. When I engage them it will hold a little bit but it is nowhere near enough to even hold the car on a hill. I bled the master Cylinder and brakes. My friend even used an auto bleeder at his work and still nothing. What could be wrong? I can hear the cylinoid clicking when I flip the switch.
frank07stanggt is offline   Reply With Quote
Old 01-23-2013, 04:24 PM   #2
Coreyw428's Avatar
Region: Arkansas
Just to check but when you hit the switch you do have to pump the brakes 1 or 2 times to make them hold..
Coreyw428 is offline   Reply With Quote
Old 01-23-2013, 04:31 PM   #3
Yeah I've tried that. Still nothing. I can feel it gripping but not enough to hold. Had line locks in an 07 gt with no problems.
Old 01-23-2013, 05:58 PM   #4
First off...props for getting that thing in there, not enough room lol.
Secondly i've ran into the same problem on street tires at the track when avoiding the water box. Got a.touch of water on the tires and no issue.
Strangely enough i've never had the problem on dr's or slicks. I guess those compounds stay cold enough to not try and hook.
My burnout procedure is pull up and set linelock. Put in 2nd gear, rev to 3k and aggressively drop clutch.
Old 01-23-2013, 06:16 PM   #5
It won't even grip enough to hold the car on a hill.
Old 01-23-2013, 06:20 PM   #6
Yeh that's strange, i activate mine at red lights when i'm lazy.
Hm...
Old 01-23-2013, 08:03 PM   #7
1996v6stang's Avatar
Sorry not tryin to jack ur thread but whats the purpose of line lock? Is it just for burnouts?
1996v6stang is offline   Reply With Quote
Old 01-24-2013, 03:57 AM   #8
Coreyw428's Avatar
Region: Arkansas
Yea basically, keeps the back brakes from engaging when doin the burnout, and like lowflyn said it's awesome to have if your lazy on the street, pull up to a light hit the switch and just set there
Old 01-24-2013, 06:19 AM   #9
If you put it on a Deadman switch you can sit staged at the light with the gas applied a little and brake boost if you are tc
Old 01-24-2013, 09:48 PM   #10
Krisis187's Avatar
Region: Nevada
Sweet
Krisis187 is offline   Reply With Quote
Old 01-24-2013, 10:32 PM   #11
Brake boost? Tc?
Old 01-25-2013, 09:07 AM   #12
If you are turbo charged you can do what is called brake boosting. You have the line locks hold the brakes while you put pressure on the gas and spool up the turbos so you are in boost whe. You launch. Gets the lag out.
Old 01-25-2013, 09:51 AM   #13
1lowGT's Avatar
I read that it shouldnt be with abs true?
Old 01-25-2013, 10:18 AM   #14
Can u do that with a standard? This might be dumb but can you stage a standard the same way as u do an auto? Like be braking and givin it gas without the tires spinnin?
Old 01-25-2013, 10:20 AM   #15
What shouldn't be true?
---------- Post added at 01:20 PM ---------- Previous post was at 01:18 PM ----------
Yeah you just can't let out of the clutch all the way.
Old 01-25-2013, 10:27 AM   #16
Ahhh so it seems like that would be real bad on the clutch then right?
Old 01-25-2013, 10:29 AM   #17
Yeah not something you'd wanna do with your daily.
Old 01-25-2013, 01:20 PM   #18
Yeah didnt sound like it lol
Old 01-27-2013, 04:29 PM   #19
I have abs and haven't run into any issues...
Old 01-27-2013, 05:52 PM   #20
Yeah I found a write up on svt performance with better instructions so i'm going to go back through it.
Old 01-27-2013, 08:37 PM   #21
Where did you mount yours? Mine is directly under the master cylinder above the distribution block.
It's a one handed operation with those giant valve covers.
Old 01-27-2013, 08:48 PM   #22
It's right under the master Cylinder. I took the master Cylinder out to put it in. Still was a pain.
Old 01-28-2013, 10:47 AM   #23
1lowGT's Avatar
Nice. How much does this cost. Easy to install?
Old 01-28-2013, 10:48 AM   #24
It's 150 or so for the setup and honestly a pain to install...
Old 01-28-2013, 10:50 AM   #25
1lowGT's Avatar
Any place where I could get them installed? And are they good to have like pros cons?
Old 01-28-2013, 06:23 PM   #26
taylor98gt's Avatar
Pros: keeps from rolling back on hills, do some bad *** burn outs without destroying back breaks.
Cons: pain to install
taylor98gt is offline   Reply With Quote
2004 cobra
09:40 PM
