It is the same, the '97 Cobra's only put out 305 HP at the crank...
[edit]
Actually I just looked it up, the '96 through '98 V8 Mustangs all used the Borg-Warner produced T-45 rated at 320 lb-ft maximum torque, the '99 through '01-1/2 used the Tremec sourced T-45 rated at 325 lb-ft--though not enough difference to matter even if it's true.
[/edit]
2003 GT, UPR X, FRPP 24lb/h, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force tuned, Steeda UDPs, Ralco RZ flywheel, RAM HDX clutch, 3.73s, 262 rwHP/305 lb-ft. Beginner's Guide to Bolt-ons
Engineering is at its base making what you want from what you have; at its extreme it is making what you want from what you can get.
