Changing fuel filter - Mustang Evolution
Old 01-25-2013, 08:20 PM   #1
Balltaatic01's Avatar
When changing the fuel filter do I need the fuel line disconnect tool or can I get by without it?
Balltaatic01 is offline   Reply With Quote
Old 01-25-2013, 08:25 PM   #2
maldog's Avatar
Region: Nevada
I have a 06 GT, but I just pinched in the tabs and pulled it apart.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 01-25-2013, 08:26 PM   #3
1slosix's Avatar
you'll want the tool on your model trust me....don't forget to flip the inertia switch in the trunk...super simple swap though overall
carving corners like a boss
Old 01-25-2013, 08:29 PM   #4
deadsp0t's Avatar
On my 95 I popped it off with a flat head and the new filter had new clips..
That's unimpressive
Old 01-25-2013, 08:33 PM   #5
What does the disconnect tool do exactly?
Old 01-25-2013, 10:32 PM   #6
1slosix's Avatar
it slides in between the fuel filter and the fuel line..expanding the line to let the bead on the filter slide out easily...the reason i recommend the tool is to expand it evenly so you don't distort the line if you add to much pressure with other tools.
Old 01-25-2013, 10:53 PM   #7
maldog's Avatar
Region: Nevada
If you're going to keep your car for any amount of time the tool is the way to go.
Old 01-25-2013, 11:08 PM   #8
1slosix's Avatar
plus a pack of disconnect tools will work for the fuel, transmission, and a/c lines so they do multiple jobs
Old 01-26-2013, 07:02 AM   #9
Ok thanks y'all
Old 01-26-2013, 07:26 AM   #10
Just don't have your head under it when you pop them off. Gas is not a good flavor
Old 01-27-2013, 07:51 AM   #11
v8pony's Avatar
Without a doubt 100% get the disconnect tool for a new edge, I thought I could get by without, I tugged and tugged and those lines would NOT come apart, went and got the 7$ disconnect tool and had it done in 5 minutes....make sure you bleed the gas valve in the engine bay, it's in front of the TB looks like a tire valve..the more you bleed that when you disconnect the fuel switch in the trunk, the less gas will come spewing out of the filter upon removal
2002 5spd GT
Feb 2013 Mustang of the Month
01:10 AM
